I got this during the week, I’ve been looking for a solution for my indicator stalk for a while and finally found someone selling them
You can see how mine had been fixed in the past by my grandpa. Not his best work
The red wire needs to get unsoldered from the column end, then the old broken bit gets removed and it all comes out. Next is a quick clean up of the end of the stalk and the electrical contacts
The plastic end is pressed on first, then the spring and the bulb holder. The wire gets resoldered and then it’s ready to go!
I got it from the user Moita over on
http://mk1-forum.net/ . It was about $50 including post which is a lot cheaper than buying a new cheap repro one, and it means I get to keep the original one with the right date code
