hey fellas,
i was quoted a while back $600 to fix a rust bubble in the midle of the bottom of the windscreen and around the corners of the rear window, not including painting (1 rust spot in each window)
i know that this is a rip of as fibre glass kits cost $20
the bubbles around the rear window are very small (taken the window n rubber out)
should i just sand them back and fill with a TINY bit of bog?....will it work?
or is fibre glass the go?, anything i should look out for?
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE
yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
