screw it up to lean the mixture, screw it down to richen. So looking down at the carb, over the engine, anti-clockwise makes it lean.
I always find it easiest to get a bolt in my hand, and turn it around so it's pointing the same way as the thing I want to do up, then turn it through my fingers - and NO, I don't turn maps upside down to read them
find yourself an old carb, and pull it apart and see how it works..... gotta start learning this stuff somewhere
did I tell you that I won a
trophy?
