What did you do on your Mini today? https://www.ausmini.com/forums/viewtopic.php?f=2&t=52415 |
Page 556 of 569 |
Author: | justfanginaround [ Sun Sep 17, 2017 3:45 pm ] |
Post subject: | Re: What did you do on your Mini today? |
Changed the oil and filter, modded the bonnet hook to clear the oil cooler, modded the bonnet latch to clear the airfilters and made an adjustable oil pressure relief now runs 65 psi cold and 55 psi hot idle. Found I have oil being blown out the dipstick but not sure what to do with that just yet, hopefully after a few hundred k's it settles down as it's only a fresh engine. |
Author: | Phil 850 [ Sun Sep 17, 2017 8:36 pm ] |
joyce1bro wrote: Got these back the from the painters the other day so i got to put them on!! Love em to bits!! They are truly beautiful |
Author: | joyce1bro [ Mon Sep 18, 2017 1:53 pm ] |
Phil 850 wrote: joyce1bro wrote: Got these back the from the painters the other day so i got to put them on!! Love em to bits!! They are truly beautiful thanks phil |
Author: | 9YaTaH [ Mon Sep 18, 2017 3:37 pm ] |
justfanginaround wrote: Found I have oil being blown out the dipstick but not sure what to do with that just yet, hopefully after a few hundred k's it settles down as it's only a fresh engine. Sounds like you need to look at your breather set-up...right now |
Author: | justfanginaround [ Mon Sep 18, 2017 6:39 pm ] |
I have a clutch breather and one off the rocker cover going into a pcv on no:3 inlet port. It's all fine untill I venture over 6k hense my thinking of a few hundo more km's |
Author: | 9YaTaH [ Tue Sep 19, 2017 8:19 am ] |
justfanginaround wrote: I have a clutch breather and one off the rocker cover going into a pcv on no:3 inlet port. It's all fine untill I venture over 6k hense my thinking of a few hundo more km's PCV been serviced? "Rubber hose" going to PCV/Inlet not collapsing? Maybe need a catch tank if you are doing those sort of REVs... |
Author: | justfanginaround [ Tue Sep 19, 2017 6:32 pm ] |
new pcv from auto part shop, so it's not old yet. I'm thinking catch an maybe. Had a new experience on the way home from work, got stuck in 4th, rolled to a halt to see whats up .....the rear roll pin fell out of the gearshift ... new one fitted and wire tied so it shouldn't happen again. One of the joys of owning a daily driven mini |
Author: | timmy201 [ Tue Sep 19, 2017 6:36 pm ] |
At least you have to sort out the issues straight away, some of us would leave in the garage for a few weeks first! |
Author: | Phil 850 [ Sun Sep 24, 2017 7:53 pm ] |
Replaced the felt bush in the bottom of the steering column. Adjusted the trafficator lever to cancel properly while I was at it. |
Author: | cruiser23 [ Sun Sep 24, 2017 8:54 pm ] |
Fitted the grille, moustache, bonnet and latches. I'm getting close now. |
Author: | Matt I [ Sun Sep 24, 2017 11:06 pm ] |
Fitted this. |
Author: | kiwiinwgtn [ Sat Sep 30, 2017 7:36 pm ] |
Fitted some genuine ripspeed hi lows no more rubbing on the rear. Stiffened the car up to. Handling much better as well. Need to let it settle and will lower a little more. |
Author: | cooperess [ Sat Sep 30, 2017 10:30 pm ] |
Started working on my newly aquired Cooper S Mk2. Removed Front bumper Alternator Power Brake Boaster Oil Cooler Distributor Heater Piping Air Horns |
Author: | TartanRed [ Tue Oct 03, 2017 8:41 pm ] |
Got the clutch hydraulics and brakes bled on my 850 restoration after a total rebuild from scratch with new everything, including pipes bent up by hand and flared etc. Has been a long job but feeling very pleased tonight! Now to drop the new donk in, hook it up and get it running before Minifest in four weeks' time. Sh!t... |
Author: | 8700s14 [ Tue Oct 03, 2017 10:04 pm ] |
TartanRed wrote: Got the clutch hydraulics and brakes bled on my 850 restoration after a total rebuild from scratch with new everything, including pipes bent up by hand and flared etc. Has been a long job but feeling very pleased tonight! Now to drop the new donk in, hook it up and get it running before Minifest in four weeks' time. Sh!t... Haha, and I thought I was in trouble for getting my car ready for Minifest! All things going to plan I should have mine registered before the end of October! |
Page 556 of 569 | All times are UTC + 10 hours |
