timing chain https://www.ausmini.com/forums/viewtopic.php?f=2&t=5745 |
Page 1 of 2 |
Author: | J_A_M [ Tue Mar 22, 2005 9:02 pm ] |
Post subject: | timing chain |
How much sideways movement should there be in a timing chain? My original 998's chain seemed to have sh!tloads of movement.... |
Author: | gafmo [ Tue Mar 22, 2005 9:03 pm ] |
Go Double or replace the chain..It maybe an Idea to check for worn sprokets |
Author: | benjamin [ Tue Mar 22, 2005 9:03 pm ] |
best to replace it get a double row one if so |
Author: | J_A_M [ Tue Mar 22, 2005 9:15 pm ] |
yea I am going ot replace....I just wanted to know if that was normal. Double sounds good. |
Author: | aaron [ Tue Mar 22, 2005 9:39 pm ] |
NO, It should have pretty minimal movement. Too much movement and the timing would be all over the shop. Variable cam timing in a bad way! Double row is the way to go. $7 for the chain. Kazjim may have one left. Thats where i got mine for th clubby, when i get round to it. Cheers Aaron |
Author: | gafmo [ Tue Mar 22, 2005 9:46 pm ] |
Best way to check is Flex it between both hands at each end...Like a Wobbel Board...(I don't Know but it works)...Or Close the sides to gether, Eye Level and see how much the chain flex..Should not be to much for a good chain.... Measurment I think you may have to by one anyway..re-assurance Things |
Author: | J_A_M [ Tue Mar 22, 2005 9:51 pm ] |
i reckon the movement of mine was about 15-20mm all up, from one side to the other! I knew straight away it wasn't right.... Yes, the motor ran like a dog!!!!! |
Author: | drmini in aust [ Tue Mar 22, 2005 9:54 pm ] |
If buying duplex chain, it is all crap these days ( read.. loose) except the endless Iwis race chain. That is good stuff but at around $60 it better be. If you can get it. I run a toothed belt drive, but even they are made in China now and are crap too- very flimsy. So I put the old Dayco one back on until I get some decent kevlar race ones from the states. |
Author: | gafmo [ Tue Mar 22, 2005 10:00 pm ] |
Whats the next best then..Myself $60 is fine But for someone else |
Author: | drmini in aust [ Tue Mar 22, 2005 10:03 pm ] |
Not much to choose. I would have thought the AE chain would be tighter than it is. I used to get Renolds duplex chain from work years ago- now that was good chain! and cheap toooo..... |
Author: | gafmo [ Tue Mar 22, 2005 10:04 pm ] |
drmini in aust wrote: Not much to choose. I would have thought the AE chain would be tighter than it is.
I used to get Renolds duplex chain from work years ago- now that was good chain! and cheap toooo..... What was the chain we saw resently |
Author: | drmini in aust [ Tue Mar 22, 2005 10:06 pm ] |
AE- you still have the box.. |
Author: | gafmo [ Tue Mar 22, 2005 10:07 pm ] |
Nope all clean now |
Author: | Chris [ Wed Mar 23, 2005 1:13 pm ] |
drmini in aust wrote: II run a toothed belt drive, but even they are made in China now and are crap too- very flimsy. So I put the old Dayco one back on until I get some decent kevlar race ones from the states.
How are you going to source the belts? I need one as well. Did you find a number? I haven't been able to chase it up due to not being able to drive for six weeks after my op. |
Author: | miniVan [ Wed Mar 23, 2005 3:11 pm ] |
there was SFA movement in my duplex chain.. my single had 30+mm freeplay.. that was awesome for timing. my motorbike chain doesnt even have that much (25mm) |
