Mini Laminated Windscreen Weather Seal https://www.ausmini.com/forums/viewtopic.php?f=2&t=96072 |
Author: | cooperess [ Thu Sep 21, 2017 9:51 pm ] |
Post subject: | Mini Laminated Windscreen Weather Seal |
Where can I buy the rubber windscreen surround for a Mini laminated windscreen? I bought one but it appears the groove is too thin and would only fit a standard zone toughened screen or back window. |
Author: | winabbey [ Fri Sep 22, 2017 7:29 am ] |
Post subject: | Re: Mini Laminated Windscreen Weather Seal |
If no-one else responds you may need to get on the phone and ring around. viewtopic.php?f=41&t=83593 |
Author: | Bill B [ Sun Sep 24, 2017 10:34 am ] |
A few years ago I had trouble with a new seal that wouldn't let the glass fit into the frame because the seal was too full in the centre section. Bought another from MG Spares in Smithfield that worked. A long time ago I went to a laminated screen from a toughened type without changing the seal as the difference in glass thickness wasn't a problem. Might be different now. |
Author: | gtogreen1969 [ Thu Apr 06, 2023 7:29 pm ] |
cooperess wrote: Where can I buy the rubber windscreen surround for a Mini laminated windscreen? I bought one but it appears the groove is too thin and would only fit a standard zone toughened screen or back window. You might have to get O'Briens to do it if there are no Mini Businesses that stock the rubber you need. |
