TartanRed wrote:
Hi Mark I recently fitted one of the Mangoletsi top mount linkages on a Weber DCOE. When I initially set it up roughly I was only getting about 3/4 throttle. So I held the throttle pedal flat to the floor and then pulled the cable through with hand tension while I used the adjustment in the linkage to vary the ratio between the throttle pedal and the carby linkage until the travel at the pedal would deliver 100% throttle when fully depressed. It seemed to have worked fine with no sticking. The only thing I have noticed is that even with the Weber internal spring and the twin springs on the linkage, the pedal feels lighter than the single spring I had on my old single SU...
Thanks. I think I've solved my setup issue.
If your pedal feels light you can adjust the spring tension on the linkage to achieve a better feel.
