It is currently Sat Apr 20, 2024 3:46 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 52 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sun Jan 31, 2010 7:38 pm
I have a new toy to play with while the S is away.
PostPosted: Sun Jan 31, 2010 7:42 pm
This space for rent
I reckon we've got about equal chances of finding spares :lol:
PostPosted: Sun Jan 31, 2010 7:43 pm
I think it needed to go off to the blaster as well as the shell!
PostPosted: Sun Jan 31, 2010 7:52 pm
When I pulled it apart I found that it is so simple and that the only parts that wear out are pretty easy to make or find.
Be very careful when pulling one apart as there are little non-return valves that fall out of the banjo bolts when you undo them.
The valves are just a pair of plastic/fibre/mica discs in the vacuum side and a ball bearing in the pressure side.
I would bet that if the vacuum side is not working it will be a missing valve from where the previous owner has lost it.
Funnily enough it is now dismantled in the shed and going to the blaster in the morning.
PostPosted: Sun Jan 31, 2010 7:54 pm
It should have a resto thread (true!). There's a few out there needing overhaul.
PostPosted: Sun Jan 31, 2010 7:58 pm
I may do that. :wink:
PostPosted: Sun Jan 31, 2010 8:25 pm
This space for rent
On a slightly related note, I realised today that I'm officially getting old... I stuck an extra inch of ride height on it to get it off the bump stops and improve the ride quality.. :roll: :lol:
Users browsing this forum: No registered users and 23 guests
