It is currently Wed Jan 29, 2020 12:15 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Oct 01, 2010 1:33 pm
How to set/check end float on the primary gear and drop gear.
With suggested measurements please :)
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Thu Oct 07, 2010 6:45 pm
Drexxle wrote:
i would like a full parts list for each car, cooper, vans, clubbies, k's including part numbers so its easier to place orders. I realsie this list could be rather large, so maybe adding them to the bottom of each how-to
PS, i just did all the front control arms etc, so i have heaps of pics. also a can explain a handy way to do it without a cone compressor. so im up for putting my two cents worth in.
drexxle all the parts numbers are in the mini king book with all the differant models, not sure if thats what you are after
PostPosted: Thu Oct 07, 2010 8:38 pm
Give Ash some flowers Nick .
- How to assemble the front subframe and fittings (arms, CVs, etc) (24/9/2010) [Moriarty]
- How to change bottom suspension arms? (24/9/2010) [mattsmadmini]
- How to change drum to disc (24/9/2010) [mini is my ride]
- How to fix the window winder (i think this has been done) (24/9/2010) [mini is my ride]
- How to set the lock mechanism up for a clubman (24/9/2010) [mini is my ride]
-How to setup camshaft timing - timing your cam in (25/9/2010) [jester99]
-How to mount your engine on an engine stand (25/9/2010) [jester99]
-How to remove & replace your steering rack (25/9/2010) [jester99]
-How to upgrade to pot joints (25/9/2010) [jester99]
-How to setup your clutch & flywheel (25/9/2010) [jester99]
-a full parts list for each car, cooper, vans, clubbies, k's including part numbers so its easier to place orders (25/9/2010) [Drexxle]
-how to do rings and bearings (25/9/2010) [Gadgets mini]
-how to fit an oil cooler to a non-cooper-s body (25/9/2010) [mickmini]
-How to re-pressurize the hydro system (29/9/10) [jme]
-How to set/check end float on the primary gear and drop gear - with suggested measurements please (1/10/10) [Minimad]
Can everyone please keep it in a list! :x
PostPosted: Mon Nov 15, 2010 4:11 pm
-How to do a basic service/grease and oil change (including checking wheel bearings, play in tie rods, ball joints etc etc) and safety check.
Lots of people been asking about bearings, etc, so we might as well do a basic maintainence guide. These are great skills that help us maintain our cars, and it beats paying a mechanic to do these simple jobs.
Ryan Filippi
Minis In The Gong
ryan@minisinthegong.com.au
www.minisinthegong.com.au
PostPosted: Wed Nov 17, 2010 8:37 am
I am soon (probably 2-3 weeks) going to be installing a thermo fan into a mates mini for low speed cooling. I will be doing soldering, heat shrink, wiring a relay & switches, working out current draw to pick fuses etc. Does anyone want to know how to do this?
PostPosted: Wed Nov 17, 2010 5:28 pm
Milatsmadmini
Yes :)
PostPosted: Thu Nov 18, 2010 2:16 pm
mattsmadmini wrote:
Yes :)
Ok Matt, just for you :) Do you still have your thermo fan wired directly to the ignition circuit?
PostPosted: Mon Nov 29, 2010 9:52 pm
Just an update. I have completed the write up. Hopefully it shouldn't be too far away from being posted. I will probably upload the photos in the next couple of days.
PostPosted: Wed Dec 08, 2010 9:48 pm
Matt, please find my write up in the how to forum or click this link. Hope this helps you out.
Everyone, also please note - it contains the easy "MiniMan" way to get your radiator in and out.
PostPosted: Wed Dec 08, 2010 10:55 pm
Milatsmadmini
i did dude! this afternoon!!!
thats pretty cool, thanks for that, the relay thing was actually very easy to understand, just on the side, where did you get that adjustable switch and price etc?
Ta!
PostPosted: Thu Dec 09, 2010 5:55 am
I got the adjustable switch off of eBay. I am currently in talks with the seller as it is really only adjustable up to 70°C, not the 120°C as indicated in the ad. I have subsequently bought a Davies Craig one from Supercrap and plan to fit that. It is of a more open design so I have also bent up a splash guard to stop water getting into it.
PostPosted: Fri Dec 31, 2010 7:06 pm
-How to rebuild a mini steering rack.
You know, list of parts, which model steering racks are worth rebuilding, the actual greasy bit.
PostPosted: Fri Dec 31, 2010 8:18 pm
As I've been doing up Oz racks for a while, I'll write something up real soon. :wink:
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank @7000+, 45 Dellorto, RE282 sprint cam, 1.5 rockers, 11.0:1 C/R. Going harder with Peak ignition system fitted. :mrgreen:
PostPosted: Mon Jan 03, 2011 9:14 pm
I would like a how to on lead wiping....
PostPosted: Tue Jan 04, 2011 12:47 pm
Let me recover from the engine how to and I'll see what I can do for you :)
