It is currently Mon Sep 28, 2020 9:02 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Jan 04, 2011 12:56 pm
Phat Kat wrote:
Bubbacluby wrote:
kirby wrote:
1018cc wrote:
- How to assemble the front subframe and fittings (arms, CVs, etc) (24/9/2010) [Moriarty]
- How to change bottom suspension arms? (24/9/2010) [mattsmadmini]
- How to change drum to disc (24/9/2010) [mini is my ride]
- How to fix the window winder (i think this has been done) (24/9/2010) [mini is my ride]
- How to set the lock mechanism up for a clubman (24/9/2010) [mini is my ride]
-How to setup camshaft timing - timing your cam in (25/9/2010) [jester99]
-How to mount your engine on an engine stand (25/9/2010) [jester99]
-How to remove & replace your steering rack (25/9/2010) [jester99]
-How to upgrade to pot joints (25/9/2010) [jester99]
-How to setup your clutch & flywheel (25/9/2010) [jester99]
-a full parts list for each car, cooper, vans, clubbies, k's including part numbers so its easier to place orders (25/9/2010) [Drexxle]
-how to do rings and bearings (25/9/2010) [Gadgets mini]
-how to fit an oil cooler to a non-cooper-s body (25/9/2010) [mickmini]
-How to re-pressurize the hydro system (29/9/10) [jme]
-How to set/check end float on the primary gear and drop gear - with suggested measurements please (1/10/10) [Minimad]
-How to do a basic service/grease and oil change (including checking wheel bearings, play in tie rods, ball joints etc etc) and safety check.
-How to rebuild a mini steering rack.
I would like a how to on lead wiping....
Let me recover from the engine how to and I'll see what I can do for you :)
My brother showed me a video on lead loading from an old expert, watch and enjoy...
http://www.youtube.com/watch?v=jQ_85fp1avs
PostPosted: Tue Jan 04, 2011 1:24 pm
Great link,
All I can add to that is that I use a bit of hide for wipeing the tinning and lead around,,, in australia we call them "bats" not paddles,,, and with the filing 2 little things....
Do the first few passes using the very edge of the file, its more agressive so it will take the high dags off quicker, and always file teh panel diagonally to make sure your blending it in with the contour propperly.
Appart from that, just avoid sanding it (lead poisoning anyone?)...
Oh and the lead to tin ratio,, anything between 80:20 to even as rich as 50:50 I have used fine (I bought it by accident) ... I'm with the old guy though, 75:25 is nice... The other thing too with heating it... it has a range of "plasticity"... if you over heat it, it stops being plastic (just like they said) but before it gets to that stage, the lead and tin actually start sepperating (and you'll see it when it happens)..
Awesome link.
PostPosted: Tue Jan 04, 2011 1:29 pm
Great link,
Awesome link.
It is a great video, if you tried to put all that into words it would take a year! :lol:
PostPosted: Tue Jan 04, 2011 1:34 pm
Great link,
Awesome link.
Sounds like a challange :D
:lol:
Honestly, things like body work are very difficult to discribe in words. Its a very visual skill. And somthing like lead whiping, well pictures speak a thousand words. If anyone asked on here I would just point them to that link. You're right, people would fall asleep before they finished reading a how to on that... so much of it is just experience... you can't teach experience.
PostPosted: Wed Jan 05, 2011 12:59 pm
Great link,
Awesome link.
:lol:
Thanks Morris1100 and Phat, GTmowog also sent me som instructions on how to do it. So all of this combined i will be a pro in no time at all :D
Brenton
PostPosted: Wed Jan 05, 2011 5:35 pm
Brenton
Another tip, don't wear thongs. :D
PostPosted: Wed Jan 05, 2011 6:27 pm
Brenton
So that means Gafmo shouldn't lead wipe?
PostPosted: Wed Jan 05, 2011 7:08 pm
GT mowog wrote:
Brenton
He would try to buff the lead and get lead poisoning. :D
PostPosted: Tue Jan 25, 2011 5:43 pm
i wear a thong at my age its called a mud rope.....
PostPosted: Tue Jan 25, 2011 7:06 pm
Not a vision I needed placed in my brain :shock:
Dicko
Mini. You don't have to prove a thing.
PostPosted: Sat Feb 12, 2011 7:53 pm
- Basic 'How to maintain your brakes/clutch'. There are a few good ones out there, but nothing that's completely comprehensive.
I'll give a little background here. I want to bleed my clutch. I knew I had some old hose lying around (air hose out of a fish tank), but found it was too small to stick on the nipple when bleeding. So something that included tool sizes, hose sizes... That'd be great. As it stands, there's enough debate on how to bleed brakes/clutch - some say to hold the pedal down, some say to hold it down for as little a period of time as possible. Some say that cheap bleeding kits work, some don't. The Mini Man has his basic clutch-bleeding guide here. I think the info's mostly out there, but a nice, clear, comprehensive how to might be very handy. :)
PostPosted: Sun Feb 13, 2011 10:27 am
Give Ash some flowers Nick .
- Basic 'How to maintain your brakes/clutch' (12/2/11) [Tadhg]
Tadhg, if your clutch is irritating you give me a call / send a PM. I have some time free today and can show you how to do it. I use a 1 man brake bleeder kit and it works fine. I also have brake fluid lying around here as well for top ups (DOT 4 I think :? ).
PostPosted: Wed Aug 24, 2011 8:34 pm
Rebuilding door hinges..
PostPosted: Sat Sep 17, 2011 7:23 pm
putting the bonnet on properley lined up so it's flush and it opens easy from the front
is it that hard or just me?
PostPosted: Sat Sep 17, 2011 9:51 pm
It's fairly easy normally. The cars I've had alignment problems with have had something damaged, usually the slam panel is a bit out or the lock plunger has rounded off and it doesnt stay shut properly.
