It is currently Sun Aug 16, 2020 2:08 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 55 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Mar 06, 2012 7:12 am
Anyone got an explanation of adjustable mini suspension and how to set it up properly? In other words, explain camber, caster, toe in/out and their effects and how to set up a mini well with adjustable bottom arms, tie-rods, hi-lo's etc.
Does that make sense? I know it'll be different for every car, but I just want to know what it all means and what I should be aspiring to to get my car riding nice.
Cheers, Matt
Don't be fooled, Gruhms is not my real name.
PostPosted: Tue Mar 06, 2012 11:40 am
+1 for this too.
1978 Leyland Clubman
PostPosted: Tue Mar 06, 2012 2:48 pm
+1 for this too.
Trawl through this lot, it saves reinventing the wheel.
http://www.minimania.com/web/SCatagory/ ... e_Type.cfm
:wink:
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank @7000+, 45 Dellorto, RE282 sprint cam, 1.5 rockers, 11.0:1 C/R. Going harder with Peak ignition system fitted. :mrgreen:
PostPosted: Sun May 27, 2012 8:17 am
I reckon the repestive mini/morris, etc car clubs should hold regular technical days, the other car clubs ive been invovled with all have, its a great way to collect new enthusiasic members too. AND you get a great technical library for the future generations to keep the cars working as they should be.
2cents.
PostPosted: Thu Jul 26, 2012 3:04 pm
Give Ash some flowers Nick .
Does everyone still want a drum to disc how to done? (Keeping in mind sgc has already done a similar thread when he converted to 4 pots?). I could probably also cover changing bottom arms too if people wish. Let me know asap otherwise I wont do a write up.
Thanks, Nick.
PostPosted: Thu Jul 26, 2012 6:12 pm
I say yes.
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Thu Jul 26, 2012 8:10 pm
No worries mate. Will take some photos as I go.
PostPosted: Tue Jul 31, 2012 11:01 pm
Everyone before me wrote:
- How to assemble the front subframe and fittings (arms, CVs, etc) (24/9/2010) [Moriarty]
- How to change bottom suspension arms? (24/9/2010) [mattsmadmini]
- How to fix the window winder (i think this has been done) (24/9/2010) [mini is my ride]
- How to set the lock mechanism up for a clubman (24/9/2010) [mini is my ride]
-How to setup camshaft timing - timing your cam in (25/9/2010) [jester99]
-How to mount your engine on an engine stand (25/9/2010) [jester99]
-How to remove & replace your steering rack (25/9/2010) [jester99]
-How to upgrade to pot joints (25/9/2010) [jester99]
-How to setup your clutch & flywheel (25/9/2010) [jester99]
-a full parts list for each car, cooper, vans, clubbies, k's including part numbers so its easier to place orders (25/9/2010) [Drexxle]
-how to do rings and bearings (25/9/2010) [Gadgets mini]
-how to fit an oil cooler to a non-cooper-s body (25/9/2010) [mickmini]
-How to re-pressurize the hydro system (29/9/10) [jme]
-How to set/check end float on the primary gear and drop gear - with suggested measurements please (1/10/10) [Minimad]
-How to do a basic service/grease and oil change (including checking wheel bearings, play in tie rods, ball joints etc etc) and safety check.
-How to rebuild a mini steering rack.
I would like a how to on lead wiping....
- Basic 'How to maintain your brakes/clutch' (12/2/11) [Tadhg]
- Rebuilding Door Hinges (24/08/11) [Mike MontGomery]
I have updated the list - you will find the Drum Brake to Disc How To here: http://www.ausmini.com/forums/viewtopic.php?t=77858
PostPosted: Sun Dec 09, 2012 8:13 pm
I need a how to remove the wiper mechanism prior to painting. how to remove those troublesome nuts when they wont come undone
If its got tits or wheels its gonna cost you
1973 Solid side Leyland Mini Panelvan 1100 in Hairy Lime(Elma)
1976 Clubby project in progress
1966 Morris Mini Deluxe in need of a full resto
1971 Mini K Garden Art
PostPosted: Sun Mar 03, 2013 8:15 pm
How to wiring instrument Cluster/Gauges
How to Trace Electrical Faults
How to Engine Immobiliser
