1098 Engine Project + 4 Synchro Gearbox - Running & Driving! https://www.ausmini.com/forums/viewtopic.php?f=5&t=85524 |
Page 5 of 16 |
Author: | timmy201 [ Fri Mar 27, 2015 1:25 pm ] |
Post subject: | Re: 1098 Engine Project |
The plan is to get the machining (re-bore, head, cam, etc) done and assemble it myself. We've just finished building a house so money is a bit tight at the moment, and more importantly I do like the process of assembling things and getting them working. I did a very mild standard rebuild on my old Mazda (just rings, bearings and gaskets) and it ran great until I sold it. That should mean more photos for here, and many more questions too! It's not going to a be particularly quick build, but hopefully finished in the next year.. (Not that I have much to show for the last 10 months!) |
Author: | timmy201 [ Mon Mar 30, 2015 1:16 pm ] |
I've got a hold of a 4 sync gearbox casing. It is missing a few bits so hopefully they'll all swap over from the rod change box. Were the diff covers the same for 3 and 4 sync gearboxes? Attachment: all-photos-1328_16963561325_o.jpg
Author: | Scoop [ Mon Mar 30, 2015 5:06 pm ] |
I believe they are the same Timmy. |
Author: | drmini in aust [ Mon Mar 30, 2015 5:45 pm ] |
Yep same, only S ones were much different (had 1/8 bigger bush & seal). You can also use rodchange covers on remote boxes, but the LH one needs the pointy bit trimmed off its flange. |
Author: | timmy201 [ Mon Mar 30, 2015 6:35 pm ] |
Sorry that wasn't too clear. I should have said diff housing, the alloy bit that holds in the diff. I've got the diff side covers worked out |
Author: | Scoop [ Mon Mar 30, 2015 8:28 pm ] |
Yep, still the same. They are a matched set though (gear case & diff cover). Line bored i think. |
Author: | Scoop [ Mon Mar 30, 2015 8:33 pm ] |
I asked about changing the diff housing a while ago and the doc had a very helpful reply. viewtopic.php?f=2&t=88564&hilit=diff+housing Hope this helps. |
Author: | timmy201 [ Tue Mar 31, 2015 10:53 am ] |
Scoop wrote: I asked about changing the diff housing a while ago and the doc had a very helpful reply. viewtopic.php?f=2&t=88564&hilit=diff+housing Hope this helps. Yep, thanks for that. I remember reading something about it recently. Did you have any progress getting yours done with the pudding stirrer? I like the idea of that how it looks standard, but I've never driven one with the long stick so I don't know how nice it would be? I guess you'd need an extra engine steady or two to keep it in check.. |
Author: | drmini in aust [ Tue Mar 31, 2015 1:36 pm ] |
Danny_ has a 4 synchro remote/puddin' stirrer shift box in his Moke. It feels very good, now, but I had to build up with silver solder the tin plate's socket where the ball sits then use the die grinder and a ball stone to resize it. Then packed with molygrease. Before I did this it was like a stick in a bowl of spaghetti (worse than a worn Morris 850 shift). Parts for the puddin' stirrer shift are rare now, and apart from John Smidt or `TheMiniMan', I don't know where you would find s/h parts. |
Author: | 69k1100 [ Tue Mar 31, 2015 4:54 pm ] |
I think I have one kicking about. The pudding stirrer and magic wand are different housings though, one is a socket into the diff housing, the other is a socket held captive by a retaining plate. Then there's always the problem, second hand parts are just that, second hand :-/ |
Author: | drmini in aust [ Tue Mar 31, 2015 5:43 pm ] |
69k1100 wrote: Then there's always the problem, second hand parts are just that, second hand :-/ Amazing what worn parts can be reclaimed by hardfacing, brazing & machining, or hard chrome plating. |
Author: | Scoop [ Tue Mar 31, 2015 6:21 pm ] |
I got as far as rebuilding the gearbox. I measured it all up and it all looks good. Within a couple of thou. Just waiting on some diff parts to complete the rebuild of that and I will then install it. |
Author: | timmy201 [ Wed Sep 02, 2015 2:10 pm ] |
How do these look? Also, will the surface rust be a problem or not? Is there anything I should measure on the old boxes before I pull them to bits? Attachment: all-photos-1768_20400012678_o.jpg Attachment: all-photos-1767_20400009258_o.jpg I've also added another three SU carbs to my collection. I should count them to see how many I have now.. Attachment: all-photos-1781_20717292135_o.jpg Attachment: all-photos-1621_18944015722_o.jpg
Author: | simonw [ Wed Sep 02, 2015 2:26 pm ] |
Post subject: | 1098 Engine Project |
Did you end up getting one of these ? Found this one in a rubbish pile the other day ! What done people throw out ! Tsk tsk |
Author: | timmy201 [ Wed Sep 02, 2015 2:32 pm ] |
simonw wrote: Did you end up getting one of these ? Found this one in a rubbish pile the other day ! What done people throw out ! Tsk tsk No, still looking for a diff housing.. What gearbox is that one off, and is the shift rod seized up, or does it move/rotate? |
Page 5 of 16 | All times are UTC + 10 hours |
