Straight Cut Drop Gear Conversion - Replace In Situ?
https://www.ausmini.com/forums/viewtopic.php?f=5&t=96605
Author:  Cooper_Matrikon [ Wed Jan 10, 2018 8:37 am ]
Post subject:  Straight Cut Drop Gear Conversion - Replace In Situ?
I've had a bit of a search, but thought I would ask the question straight out, but is it possible to replace the drop gears in the car (i.e. no engine out).
I'm thinking of adding a bit more scream to Barney's already grump note with a set of straight cut drops. Yes, I know I know.
Any thoughts, suggestions, ideas would be appreciated.
Evan
Author:  minimans [ Wed Jan 10, 2018 2:27 pm ]
Post subject:  Re: Straight Cut Drop Gear Conversion - Replace In Situ?
Yes it would be possible but a bit like extracting a tooth through your arse! Just take it out and do it on the bench much less fuss and you'll need to set clearances which would be a right pain in the car.
