It is currently Fri Feb 22, 2019 12:17 am
 Post subject: Big Radiator
PostPosted: Sat May 26, 2018 8:31 pm
Will the Chinese 70mm one fit without hacking the car??
Its a Clubman
 Post subject: Re: Big Radiator
PostPosted: Sat May 26, 2018 10:16 pm
If you use roundie radiator brackets and lose the fan spacer, probably. I don't see why any Mini needs these 70mm rads unless there are other issues though...
*witty signature*
Sapphire Blue Deluxe spread across three cars and two sheds...
PostPosted: Tue May 29, 2018 12:46 pm
I have a 55mm in my roundie - I modified the shroud to pull the radiator closer to the motor and it fits fine
does 100hp at the wheels count as "other issues"?
PostPosted: Tue May 29, 2018 12:56 pm
At that stage, you might have a point.
Had the same issue fitting the 55mm rad... Squeezes in nicely with the shroud modified though.
*witty signature*
PostPosted: Tue May 29, 2018 1:03 pm
it did help... wasn't too bad on the standard radiator, but the extra capacity made a difference when it needed it
Now the blower is off, the big radiator is still there and can do motorkhanas with my kids all day at 82°
PostPosted: Fri Jul 13, 2018 7:35 pm
Thanks guys Rob suggested there may be three different types of radiator brackets .
Looking get rid of spacer on water pump and maybe run a metal fan
PostPosted: Sat Jul 14, 2018 11:58 am
I cut the inner wing shroud out and mounted the radiator directly onto the inner wing using some aluminium angle iron as brackets - one long one at the front and one very short one to secure the top of the radiator at the back. Radiator removal is a 5 minute job.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sat Jul 14, 2018 8:06 pm
Any pics please mate
Users browsing this forum: Cheeser and 5 guests
