It is currently Wed Jan 23, 2019 10:27 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 25, 2017 11:18 am
Garagedefend wrote:
yeah I'm thinking thats the easiest bet. Are there aftermarket options though or do I just have to wait to find a used longer ratio one? although I've only checked oz.minispor they seem to only have same ratio alternatives to standard
If you put a 3.1 diff in with stock Mini K or Oz rodchange gears, it make 1-2-3 the same as a Cooper S, but with a taller 4th for cruising.
Best of both worlds.
And 1/2 the price of fitting a Cooper S 1st motion shaft and cluster gear.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank @7000+, 45 Dellorto, RE282 sprint cam, 1.5 rockers, 11.0:1 C/R. Going harder with Stealth Black Box in.:mrgreen:
PostPosted: Thu May 25, 2017 11:23 am
thats perfect actually. Shorter 1 2 3 and longer 4th.
you wouldnt have one there would you? haha
PostPosted: Thu May 25, 2017 2:59 pm
No, but they are only 125 quid at Minispares UK... I fitted one to Jenk's 1330 Deluxe.;)
PostPosted: Thu May 25, 2017 3:22 pm
There are second hand ones here, you might also be lucky to find one in Australia already.
http://guess-works.com/Shop/Parts/display.htm?id=156
PostPosted: Fri May 26, 2017 8:45 am
I have straight cut gear set and drops in my car and normal driving (with a good bit of insulation) is fine when I only had insulation under the carpet on longer trips it got a little annoying at highway speeds, added some dynamat like material and padding on the firewall and MUCH better and no issues on a long highway cruise either, plus the close ratio's are just awesome and keeps the turbo spinning well.
Grant
100% Pure A Series Turbo
PostPosted: Fri May 26, 2017 9:39 pm
Could i come for a ride and listen one weekend?
PostPosted: Sat May 27, 2017 1:26 am
I may have a set of straight cut drop gears if interested brand new in the box purchased 3 yrs ago to put into a new build but didn't go ahead .
PostPosted: Tue May 30, 2017 10:54 pm
Pm sent
