| View previous topic :: View next topic |
| Author |
Message |
Gordo 998cc
| Back to top |
pigsfly n00b
Joined: 26 Jul 2009 Posts: 24 Location: Campbelltown NSW
Posted: Thu Oct 01, 2009 7:46 am Post subject: |
Well its all new, probably helps the appearance. The tunnel has made it look soooooo much better. Also - adds heaps of strength and straitness to the entire floor pan.
My plan is to do some Vizard-esk strengthening of the floor once it is complete as it could only help the rigidity of the shell...
I did fold up some custom rear floors, and have put the rear drivers in, but am going to go with standard pressed floors now I think... |
| Back to top |
pigsfly n00b
Posted: Fri Oct 09, 2009 2:00 pm Post subject: |
I couldnt find van rear floors so I have ended up using standard salon floors and will have to fill in the rear pocket section which wont be too hard...
I am picking up the rear drivers floor this afternoon from Mini King and that will go in over the weekend. Once it is all buttoned up I will be one stage closer to having it off the rotisserie and rolling.
Then I will finally be able to justify why I have put this thread in the engine conversion page as the engine/box goes in... Still churning ideas about the engine/box at the moment... we'll see what comes up... |
| Back to top |
pigsfly n00b
Posted: Tue Feb 09, 2010 1:37 pm Post subject: |
| Well... A long time since i've had any chance to work on the car... A recent split up with my misses means I now have a lot more time, and maybe even some more money to work on the car. |
| Back to top |
Archangel007 1275cc
Joined: 17 Jun 2005 Posts: 2413 Location: Burpengary, Queensland - Home of Qik Brix Racing
Posted: Tue Feb 09, 2010 5:53 pm Post subject: |
| pigsfly wrote: | | Well... A long time since i've had any chance to work on the car... A recent split up with my misses means I now have a lot more time, and maybe even some more money to work on the car. |
So that's the secret................................................  _________________ "Not Speeding Officer..........Qualifying" |
| Back to top |
pigsfly n00b
Posted: Tue Feb 09, 2010 8:37 pm Post subject: |
i can assure you - not an overly pleasant one though... The van is too bulky to fit in my bed - and being inside it aint overly pleasant either atm.
| Back to top |
Morris 1100 Causing or creating vexation
Joined: 21 Jul 2004 Posts: 13551 Location: I'm a country member. Goulburn NSW.
Posted: Tue Feb 09, 2010 8:44 pm Post subject: |
Why is divorce so expensive?
Because it is worth it.  _________________ I suppose you think I made this up too? |
| Back to top |
pigsfly n00b
Posted: Tue Mar 09, 2010 12:32 pm Post subject: |
FINALLY some progress!
I took sometime out on the weekend to get stuck into the floors. I have almost finished up the passenger side floor pans. Just have to seem weld the panel in the middle which joins the front and rear pans together.
The more I get done on the van the more I realise there is a whole lot more to do! I went into Mini King and have ordered a new (well reco'd) steering rack and column and the old ones are stuffed. Ordered new right and left guards, front apron, headlight panels, bonnet (second hand), A panels and a bunch of other little stuff...
Check out the rust in the rear panels.
I wont be doing the panel work on the top of the car as I want this to be of top notch quality - but will be supplying the panels to the beater.
Stay tuned for another update soon-ish  |
| Back to top |
simon k Yay For Hay!
Joined: 08 Sep 2004 Posts: 8999 Location: Wodonga - Vic/NSW border
| Back to top |
pigsfly n00b
Posted: Tue Mar 09, 2010 4:10 pm Post subject: |
Oh god.... I have been tossing and turning on what engine I want to put in this thing...
I dont know if I want to be the pioneer of a new conversion type - yes I know that sounds boring - but there is so much work in doing one that people have had experience with....
Then again, I do like Nissans... OMG brain hurt! |
| Back to top |
Archangel007 1275cc
Posted: Tue Mar 09, 2010 8:21 pm Post subject: |
Go the NEO engine - you know you want to!!!  _________________ "Not Speeding Officer..........Qualifying" |
| Back to top |
pigsfly n00b
Posted: Wed Mar 17, 2010 8:16 pm Post subject: |
I may just go the NEO engine... I have been talking to my good friend who also is a great mechanic and he has offered the use of his workshop to get the engine in and going!
I managed to get about 4 hours on the car last friday and got a reasonable amount done... I should be ready to put the cross brace back in this weekend! Yay! Another step closer to getting it rolling again.
Does anyone have thoughts on Vizards recommendations regarding putting a double skin on the tunnel and cross brace in adding rigidity to a shell??? Considering the NEO engine will put out a lot of torque and I want the body to be as stiff as possible without the need for a rollcage....
I will pick up my new steering rack this weekend and will begin rebuilding the subframes - a task I can do at night. Panel work during the day and mechanicals at night. |
| Back to top |
Kennomini 1275cc
Joined: 24 May 2007 Posts: 3221 Location: Yandina,Sunshine Coast,QLD
Posted: Thu Mar 18, 2010 7:43 pm Post subject: |
If your worried about the shell flexing I'd be making 2 ladder style braces bolted through the floor on each side. Just make them the same size and shape as the floor pan and have some plates on the inside so the bolts don't pull through the floor.
Personally I don't think the shell would flex that much. Have you ever put one end of your mini on axle stands and then jacked the other end up from the corner? the shell don't flex it just teeters on the stands and the jack. Mini shells are very ridged. _________________ Respect mine and I'll respect yours.
| Back to top |
pigsfly n00b
Posted: Sat Mar 20, 2010 9:00 am Post subject: |
| I have just been wondering about it. When I was working at revolution I had to put a bolt in 6 point cage into a mini. The drive before and after were chalk and cheese. It was so much stiffer! |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
adult list, amateur bbw, anal passion, asian shemale anal, gay cum in ass, her smelly asshole, bbw european parties, hardcore lesbian bdsm, nude male beach, beastiality mpegs, teen bikini voyeur, bisexual wives, drunk bitches women ckiks ho's, topless blondes, anime blowjob, bondage sluts, boob slips, , young brunettes, milf butt, cum cam, naked simpsons cartoons, free nude celeb clips, free celebrety home movies, cheerleader having sex, free naked goth chicks, , clit closeup, black cocks white sluts, wild coed porn, old creampie, cum glasses, dad fuck daughter letter, dating married women, hard gay dicks, dildo sluts, dirty jobs, female domination male slave miss jennifer, best porn dvd, ebony teen galleries, sapphic erotica blonde, ethnic gang bang, fart in face, hot teen facial, final fantasy 10 yuna hentai, gallery black fat pussy, dirty feet girls, female vulva, rape fetish, group ffm, free gay fisting photos, flexible contort pics lick self, free xxx videos free xxx, forced fuck, girl gangs, gangbang thumbnails, gay fucking video free, gothic girl- 69 eyes, dads boy, group sex big tits, free hairy mature galleries, footjob model, pantyhose hardcore, online hentai games, housewives spanked, story i kissed my sister incest, cheyenne indian religion, latin lesbians eating pussy, , free black lesbian videos, super sexy erotic lingerie, free girls live cam, machine sex thumbs, kraft maid hardware, nifty gay male stories, teen girl masturbation, mature bbw, free movie thumbnails of big melons fucking, naked young men, lacey midget stripper, milf orgy, , mouth fucking movies, free anal sex movies, how does nail fungus come off of your nails, wwe diva torrie wilson naked, freaky nipples, nude disney, amazing nurse nanako nude, women wearing nylon panties, office orgies, oral sex party, orgasm denial, blue outdoor furniture covers, paris bennett, jackass party boy song, little bo peep plus size costume, double penetration teen, free gay male porn, pornstar cricket, britney spears pregnant again, pooping in public, beach pussy, duke university rape victim, why reality tv sucks, redheads with big tits, scat fetish, underage schoolgirl, under secretary of defense for intelligence, gay black sex, free shaved teen pussy, ebony shemale galleries, nude shower scene, huge silicone tit galleries, , glass smoking water pipes, sexy spankings, stockings and suspenders free pics, porn star stud, eagles suck, spunk swallows, cum swap, tanned sluts, tattoo gallaries, teen hitchhiker, petite teens in thongs, throat stuffers, tiny nipples, cumshot tits, free toon porn, living sex toy delivery, brazilian tranny videos, 1999 trans am pictures, gay nude free twink movies, uniform sex, miniskirt upskirt, , voyeur cams, angels wife lovers free, ebony xxx porn, young naked women, punching bags for youth, waco zoo,
