It is currently Sat Jun 21, 2025 12:30 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Fri Sep 16, 2005 5:09 pm
RADIATOR EASY OUT / IN - Submitted by 'justminis'
To make this work, need to modify the bottom shroud to make it 2 pieces. This allows very easy in and out of the radiator. Please see attached pics.
You end up with a small part of the shroud (above the bottom hose) that remains attached to the rad by the screws. The other part of the bottom shroud is set up to be bolted to the engine via the bottom mount in the normal fashion. This part stays bolted to the engine.
There is a strengthening brace under this shroud (that the bottom 3mm steel mounting bracket bolts to) that you DO NOT cut thru. This strengthening brace is used to locate and support the other piece of the shroud on the radiator. A couple of locating lugs are needed here to allow this to work.
Before separating/cutting the shroud, find the spot welds on the strengthening brace on the short end of the shroud and drill these right thru with approx 1/8" drill. You should now be able to separate the 2 pieces of the shroud.
The holes you drilled are used for the locating lugs. I have used machine screws about 3/8 - 1/2" long welded to the underneath of the strengthening brace to protrude upwards. You may need to clearance the holes in the other piece of the shroud to allow it to fit easily over these screws/lugs, which should make the shroud sit back together as 1 piece again.
The next step - to make this mod successful and hassle free, it is important to ensure the engine piece of the shroud lines up with the radiator on installation, ie, straight up & down and not on an angle. Some bending of the bottom 3mm steel mounting bracket may be required. What you want is this part of the shroud sitting in the right place to line up with the rad when you put it in, not at an angle that puts pressure on the 2 piece shroud or the radiator.
It is best to set this up on a motor out of the car so that any fine tuning can be easily done. Because the radiator is so easy to install (and remove) with this mod, engine can be fitted to the car without the rad fitted.
All that is needed now to remove radiator is ?
? Undo top and bottom hoses engine end (top hose your choice),
? Loosen fan belt (to allow fan to turn),
? Undo top radiator mount bracket at thermostat,
? Remove bottom 2 shroud screws at the front of the car,
? Lift radiator straight up and out of vehicle.
PostPosted: Tue Jul 01, 2008 12:16 pm
ausmini admin
ausmini admin
Another way of removing the radiator provided by Matt Read .
The MiniMan wrote:
Removing the Mini Radiator
OK ,,, before this blows out into a frenzy of people stuffing with their radiator shrouds,,, the mini radiator is already an "Easy-out" item if you know how
There’s a simple standard easy way,,,, & then there is the "usual" misinformed , time consuming, head ache, pain in the arse way
Listen (read) & learn
Firstly, you take the 2 engine mount bolts & nuts out from the passengers side,,, then jack the engine up on that side,
2ndly you undo & remove the 2 vertical bolts that mount the bottom radiator bracket to the engine mount bracket (Not the 2 bolts that are located side ways through the lower radiator bracket to the lower radiator cowl, just leave them there),
then with the top radiator bracket & both top & bottom radiator hoses un-clamped, it’s just a matter of lifting the whole assembly, radiator with cowls attached , in one big bit, straight up & out of the hole... easy-peasy
the factory even made the later radiator cowls one piece because there really was never any reason the make it 2 pieces in the first place (except to fool the un-initiated)
It’s that easy,,, the Morris 1100 ones are even easier as they only have one bolt at the bottom.
A weenie bit of patience & a tad of practice & common sense & your radiator will be out in about 5 mins flat... & back in about 8 mins
Not all weekend like some do trying to remove all the cowl screws & removing it separately,,, WRONG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sorry but this topic really gets my back up , because it’s so easy & quick doing it the "CORRECT" way
ok,,, rant over, & again sorry but dam!!!!!!!!!!!!!!!!!!!!
no offence to anyone intended, I just mean this post as a help to any & all who listen to ideas of modifying things that just really don’t need modifying.
MadMatt "Ready" Read---> "The MiniMan"
Users browsing this forum: No registered users and 0 guests
