Anto wrote:
Sounds like something is binding somewhere, first up I would pull the clutch arm off and check for anything amiss, but it is sounds like something internal which will necessitate pulling the clutch apart.
Yeah, that's my suspicion. The clutch arm came off and was thorougly cleaned, lubed and reassembled when I changed the friction plate, so it's unlikely to be that.
Anto wrote:
Maybe the diaphragm isn't square, or the bolts aren't seated properly which would buckle the drive straps and could cause the drag you're experiencing - but if this had happened you would probably have significant clutch shudder as well.
No clutch shudder at all, it's just slow to return which lends to slippage after a quick gearchange.
Anto wrote:
By the way, when you depress the clutch do the engine revs drop?
Nope, not that I remember.
The only thing I can think is Klas may be close and the friction plate is binding on the primary gear. That
didn't get any grease when things went back together, but I really wouldn't have expected that to make such a massive difference. I don't remember which brand it was, but I think it was reputable -- B&B, or PBR, or something like that. Whatever Autobarn supply in their rebuild kit
