I had another play with my spare 850 wiper motor and a multimeter today, to see what speed I could get from it.
I have an ex-Fiat 124 Sport wipers 0-68 ohm variable resistor wired into the field circuit.
0 ohms gave standard speed, increasing it up to 22-27 ohms gave more than a 2x speed increase.
At 35 ohms it was no faster than at 27 but had insufficient torque to start.
So....
If you want 2 speed wipers here's what to do:
1. cut one of the field wires and solder some 2 core flex to the 2 cut ends.
2. run the flex out to an on/off switch.
3. wire a 22 or 27 ohm, wire wound 10W resistor across the switch too.
With the switch ON you will have standard speed, with the switch OFF you will have approx 2x standard speed.
BTW I didn't just make this circuit up, I copied it back in 1967 from a Popular Mechanics? magazine, it worked in my 850 back then too.
Why does it work? I'm not an electronics guru so I don't know, but it does.
<edit> typos- I had ON and OFF arse about.
