It is currently Mon Jun 23, 2025 3:56 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Aug 11, 2011 7:21 pm
http://www.youtube.com/watch?v=NZ_6UegeOvM
http://www.youtube.com/watch?v=U9i8IqipvS8
http://www.youtube.com/watch?v=HCG51NPW3CI
more pic to come
thx
jason
PostPosted: Thu Aug 11, 2011 8:33 pm
Looks pretty good!
Can I ask what the cost would be for a kit that gives me subframe, driveshafts, and any special custom brackets?
(i'd do bodywork, brakes, electricals and engine)
:D
 Post subject: cost
PostPosted: Thu Aug 11, 2011 8:57 pm
well work it out. i m doing 3 mini now 77 cluby 68 round noise turbo and 64 na round noise .from around $2500 from subfame, driveshafts and intake amd brake kit for around $1500 for 4 wheel disc brake kit 248mm front and 230mm rear from gti swift and kits are for 89 to 98 gti swift
two mini's have be passed for engineering just need to get ready for rego
thx
jason
[email protected]
 Post subject: sub fame
PostPosted: Thu Aug 11, 2011 9:14 pm
http://www.youtube.com/watch?v=tWfMLhHXqNo
PostPosted: Fri Aug 12, 2011 12:28 am
Why do the rotor faces have paint on them?
:lol: :shock:
PostPosted: Fri Aug 12, 2011 12:54 am
Die Die Die!!
would love some more info/pics of this conversion..
could make a list of exactly whats included with pic for what price ? just to clarify for some people ?
PostPosted: Fri Aug 12, 2011 9:15 am
x 2
What is the overall cost of a drive in drive out job?? So
dropping off a mini and getting a gti engine and subframe and brakes etc conversion done and having it engineered and on the road again registered to drive home?
 Post subject: driver in
PostPosted: Fri Aug 12, 2011 9:53 am
from around $6500 + running gti swift 89 to 98 [you can get one for about $500 to $1500 ] and $1200 for engineering
for na clulby add $1000 for round noise need work
and can trubo any mini
for driver in gti in driver out
motor fitted
gti front brakes well need 13in wheel to fit
all wired
gti tank fitted
gti seat fitted if wanted
gti dash
PostPosted: Fri Aug 12, 2011 10:02 am
jasons work is awesome, I have had him to do a few bits for my swift mini, he knows his stuff & very fair with price & quick service/ turn around.
highly recommended lads.
PostPosted: Fri Aug 12, 2011 11:05 am
For the work it is not bad value, but for the money ~$9,000 you could spend less on an A-Series and have more than 100HP. Probably closer to 150HP with a cross flow head.
PostPosted: Fri Aug 12, 2011 11:22 am
So why didn't you do that? :lol:
PostPosted: Fri Aug 12, 2011 11:39 am
Because i wanted more power - on 22psi boost i'd make 250HP at the crank.
If you wanted to turbo the G13B and go for big power sure, but as an NA proposition i don't buy into it.
Sure you get fuel economy, 5speeds, fuel injection - but at the end of the day these are things people care about in daily drivers - how many people daily drive minis these days.
I have driven an N/A G13B in a mini and a an a-series is easily made to provide that kind of performance reliably.
PostPosted: Fri Aug 12, 2011 7:17 pm
How much just for a bare frame as a diy kit?
Simplify and add lightness
PostPosted: Sat Aug 13, 2011 4:48 pm
if I had a car space at work, i would be driving my Rover every day.....
Although I agree and disagree with your comments. I used to have a 13B conversion which i picked up (whole car rebuild from ground up and engineered/registered) for $8k so i agree that on that basis, this seem expensive.
That car was na, and had a great power to weight ratio, kept up with traffic well, did everything well actually and although I wasnt running 10 second quarter miles, it did have the right level of "modern" that i thought it woudl have been a perfect all rounder car. Sadly, the choice of wheels/brakes meant it didnt have a satisfactory turning circle (i had to do three point turns around roundabouts sometimes) and so i got rid of it pretty quick.
For an all round modern Mini, IMHO its hard to go past an original 1275 manual "tweaked" Rover with air con... *sighs* if only I had gone manual when I got mine................. :lol:
PostPosted: Sat Aug 13, 2011 5:56 pm
I drive a Mini everyday....
