It is currently Tue Aug 12, 2025 2:18 am
PostPosted: Wed Sep 27, 2017 9:01 pm
Has anyone played around with a more modern solution to the mechanical speedo cable while still maintaining the original look?
I run a Weber box and have very little if any room for accommodate a speedo cable. I have seen a bit of feedback on the 90 degree adaptors being prone to failure.
I know that a lot more GPS options are becoming available for speedos, but I really would like to keep the original smiths look.
Sent from my HTC_PN071 using Tapatalk
PostPosted: Wed Sep 27, 2017 9:11 pm
You can get a Smiths speedo with electronic internals, James here has one installed, apparently it's pretty good
http://www.minispares.com/product/Class ... o%20search
PostPosted: Wed Sep 27, 2017 9:39 pm
I made this, 5 years on it still works like a champion
PostPosted: Thu Sep 28, 2017 3:59 pm
I have 90 degree adapter on my car and have no issues at all, nor I should because it's designed to do the job. Mine is one that was fitted to Jaguars, not sure which models. Wasn't expensive, got it from a wreckers. Sorry, can't remember the price but $30 rings a bell.
Ring around Jag wreckers..
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Thu Sep 28, 2017 7:22 pm
Ring around...
Ahhh cool. Same vintage Jags?
PostPosted: Thu Sep 28, 2017 7:23 pm
Explain this a bit further?
PostPosted: Fri Sep 29, 2017 6:12 am
Sorry I don't recall what model/ vintage Jags they come off. I got mine from a Jag wrecker who said he had sold a few to Mini owners with our setup. They are perfect for the job, takes 2 minutes to install and the cable rests against the firewall wall away from the extractors.
67 Deluxe
Dry suspension
PostPosted: Sat Sep 30, 2017 9:44 am
I'm thinking I might try and combo this http://www.minispares.com/product/Class ... |Back%20to
with retro something electronic into my speedo.
PostPosted: Sat Sep 30, 2017 10:47 am
Electronic speedo drive. The little black dot on the speedo drive boss (right hand side) is a Hall effect switch, the silver dot in the white ring on the drive itself (left hand side) is a magnet. When the magnet passes the switch it pulses. I didn't really expect it to work
I originally made it to talk to a speedo I built out of a Subaru speedo head, mini odometer and mini speedo face.
The electronics I made didn't work out (too much electrical noise) so it now talks to my ECU which I Bluetooth to a phone in a holder on the dash. My speedo doesn't do anything, but one day when I don't have 10,000 other things on the go I'll make it work
PostPosted: Sat Sep 30, 2017 8:25 pm
Ah, so this just sits down on the end of the gearbox as if it is the speedo cable drive, but it just generates a pulse for an electric speedo.
Very clever :D
PostPosted: Sun Oct 01, 2017 4:56 am
If you buy the Smiths electronic speedo for ~$500 it comes with a similar mounted sensor.
PostPosted: Sun Oct 01, 2017 7:53 am
I have an angled speedo converter if it's required. Just screw one end into your speedo and voila.
PostPosted: Sun Oct 01, 2017 8:47 am
Yeh that's what I'm trying to avoid haha.
PostPosted: Sun Oct 01, 2017 8:48 am
Required as in you're willing to sell or you might use yourself?
Users browsing this forum: No registered users and 164 guests
