It is currently Tue Jul 29, 2025 3:45 pm
 Post subject: Mechanical fuel pumps
PostPosted: Tue Jun 07, 2005 11:56 am
I read somewhere that you should not put compressed air through a mechanical fuel pump.
Why?
Does it do something to the diaphram?
PostPosted: Tue Jun 07, 2005 12:31 pm
yep there are valves and i think a rubber diaphragm that opens and shuts with the lever action provided by the camshaft
so only the lever action will open and shut valves
blowing air in it wont go through coz there will be shut valves
Inconspicuously Conspicuous
PostPosted: Tue Jun 07, 2005 12:34 pm
Why would you want to do that/\?
Chris
Everything I like is either
PostPosted: Tue Jun 07, 2005 12:35 pm
to clean it out!
PostPosted: Tue Jun 07, 2005 12:43 pm
if you want to clean it out, get an overhaul kit (diaphragm, balls for the one way valves, seals) pull it apart and then clean any goob out. believe me it is an absolute sinch to do.
PostPosted: Tue Jun 07, 2005 12:45 pm
Yea I put air through mine to get and fuel out that might be still in there. :?
Mine doesn't seem to come appart like the older ones with screws on top. This appears to be a sealed unit. It's a late clubby type.
PostPosted: Tue Jun 07, 2005 1:14 pm
That type didn't last long. I still don't get it....the compressed air bit that is. The only way to fix a mechanical pump is to pull it apart.
Chris
PostPosted: Tue Jun 07, 2005 1:15 pm
what does it look like? i have an electronic fuel pump also, but i dont know if its stock or what.. it makes too much noise in any event..
PostPosted: Tue Jun 07, 2005 1:43 pm
Mount it on a square exhaust mount, that will make it run quiet.
Pete
PostPosted: Tue Jun 07, 2005 2:02 pm
ahh cool, still i'm wondering how that works :D
PostPosted: Tue Jun 07, 2005 5:01 pm
Pull the cap off and have a look. Failing that do a google. I am sure there is somewhere om the net that will tell you how.
Chris
PostPosted: Tue Jun 07, 2005 5:39 pm
Fuel pump, hmmm thats one of the last things to put back on an engine. JAM's getting close then.....
Aaron
Users browsing this forum: No registered users and 114 guests
