It is currently Sun Aug 03, 2025 12:12 pm
PostPosted: Sat Jul 21, 2018 4:26 pm
Hello All.
I have fitted 3 headlining's in the past ,always a difficult job ,today I fitted a headlining with no real problems .I started from the Centre of the mini adhered lining to both pillars made sure the steel bow was vertical, stretched each end and I used small plastic coated spring clamps to hold ends in position. Worked down each side all went well. The job took 4 hours ,as I am very fussy about everything I do. No heat gun used as they did not use them in the BMC factory .I will recheck the lining tomorrow. If there are wrinkles in the lining I will use the old trimmers trick Boil the kettle in the car and as the lining cools wrinkles should disappear and the lining will tighten. FYI.
Allen
PostPosted: Sat Jul 21, 2018 5:00 pm
My mate is like you and he used heat Real good old school beater painter .Many years later its still great job
PostPosted: Sat Jul 21, 2018 5:04 pm
I have also heard the lining trim for minis is what VW use ,supposed to be excellent material.
PostPosted: Sat Jul 21, 2018 5:15 pm
Mine is an old Ford pattern Closest we could get and it was hand made by a local guy had a business at Maitland before he retired.Bob did a great job.The first one we bought would not fit
