It is currently Sun Jul 27, 2025 10:24 am
 Post subject: Fuel tank pickup removal
PostPosted: Wed Jun 24, 2020 11:38 am
I am about to refurbish the interior of the fuel tank and wonder how to protect the pickup mesh if i choose to coat the inside..
I know others have put the coating in there , so looking for some guidance on how to not block the pickup pipe.
The tank may or may not need the coating ... so i suppose i should do a fill/leak test now while its out ....
Anywho
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Wed Jun 24, 2020 9:33 pm
Dr Mini always says to poke something up the outlet pipe to remove the mesh completely and run a proper modern fuel filter underneath the tank...
PostPosted: Thu Jun 25, 2020 5:55 am
If you do this make it a decent sized filter so restriction doesn't starve the pump.
I have used Falcon or Holden metal case ones before.
Don't use Purolator etc glass case filters under there they can get broken.
PostPosted: Thu Jun 25, 2020 8:20 pm
Legends . Thank you Dr mini and simonk
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri Jun 26, 2020 10:43 am
I was under my car last night - I just have a basic straight through plastic filter, nothing special - about 1.5" diameter and maybe 2.5" long. Even when I was running supercharger/injection with 100bhp@atw I used a pretty normal type of filter before the fuel pump
