It is currently Sat Jul 19, 2025 8:29 pm
 Post subject: Handbrake sector detail
PostPosted: Mon Jan 31, 2022 3:32 pm
Another quick question about rear subframe parts: the handbrake sector is held on by a nylon washer, a spring and a spire clip on a hydro trailing arm .
What is the fitting sequence?
I have always fitted the nylon washer against the trailing arm and spring on top but the parts catalogues show the spring first.
Have I been wrong all these years?
And I haven't even got to the exhaust system yet!
PostPosted: Mon Jan 31, 2022 4:12 pm
I'm baaa-aack! mwa ha ha!!! ;-)
I would have thought the nylon to protect the weaker part, so the pivot allowing it to work smoothly.
Cheers Dave.
PostPosted: Mon Jan 31, 2022 4:17 pm
This is mine. I think I took pics of the before so replicated that sequence. My Mini guru mechanic would also have advised.
PostPosted: Mon Jan 31, 2022 10:46 pm
I assembled mine the same as Dougs'. Not really a fun job, I'm glad glad I had a couple of spare retaining clips.
PostPosted: Tue Feb 01, 2022 7:53 am
I think 21A1512 Nylon Thrust Washer for Hand Brake is to stop water getting into 21A1507 Hand Brake Quadrant shaft which should be greased.
PostPosted: Tue Feb 01, 2022 8:18 am
Seems to be unanimous. The nylon washer does look like a seal for the pin.
Thanks for your contributions.
PostPosted: Tue Feb 01, 2022 12:43 pm
It’s a good idea to check the brass bushings as well. Two each side. One of my arms was missing one.
PostPosted: Tue Feb 01, 2022 1:18 pm
Yes. Did check those earlier. Surprisingly little wear so OK. If I needed any, not sure if there is a part number for them or just some standard sized bushing.
Interestingly, the pin in the cable sector was not perpendicular on either one. Bought 2 Minispares replacements and they aren't perpendicular either. Starting to think they are meant to be off-square. For clearance somewhere, or pivot angle on cable? Or just bent?
PostPosted: Tue Feb 01, 2022 1:39 pm
A mate just turned me up another one out of brass. My quadrants were similarly off. I kept them “sided” , cleaned them and put them back in their respected arms. Because they were both a bit off, I left them alone.
PostPosted: Tue Feb 01, 2022 3:38 pm
I began to think the same but the old ones are back in the trailing arms now and turn through 360 degrees.
The 2 new Minispares ones share the same part number and are not labelled as LH or RH.
PostPosted: Tue Feb 01, 2022 8:35 pm
PostPosted: Wed Feb 02, 2022 11:23 am
Thanks eightfifty for the drawings.
From the dimensions shown, as best I can understand them, the coil spring does not pass through the centre of the plastic - it bears against the plastic washer at its thickest section of the washer and not in the centre area.
The 'undercut area' in the centre of the plastic washer you are uncertain about is maybe because the drawing is not to scale. What looks like deep counterbores from both sides, are only light chamfers on the actual part.
PostPosted: Wed Feb 02, 2022 2:49 pm
