It is currently Wed Jul 30, 2025 2:30 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jun 14, 2005 1:43 am
Not sure...
this is what i've got:
PostPosted: Tue Jun 14, 2005 4:55 am
Chris,
Checked out my car(s) and both the same. Blue high beam light is on the top of the centre dial between the temp and fuel gauge. All cars I've owned have a blue warning light for the high beam - must be some international standard. The red light on the bottom of the speedo is not used for anything - doesn't even have a bulb in it. Hope this clears things up.
BTW, if you want, I'll scan the owners manual - which is for the Mini Clubman and GT, Mini 1100 and mini Van, produced in 1972 by Leyland Australia and is publication No. TP828A - and send you a copy.
Regards,
Gavin
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Tue Jun 14, 2005 3:02 pm
ClubmanGT wrote:
Chris,
Regards,
Gavin
Yes please I would like a copy. In mine the blue light is at the bottom of the speedo. This instrument panel was not in a car I got it as part of a deal and don't know its history. It certailnly looks standard. The little blue lens looks like it is meant to be there and sits behind tiny plastic clips. All the others are glued in and this would make it difficult to swap them around. Now I don't know what to do as I intended to change the speedo over and this has complicated things. If I had a car to put it in I could try the warning lights to see what happens.
Chris
Everything I like is either
PostPosted: Tue Jun 14, 2005 3:15 pm
Could yours be from a pommy one? as I think they were different.
Pete
PostPosted: Tue Jun 14, 2005 5:52 pm
Hey Gavin
Wouldn't mind a copy of the scanned manual down here in Chch if you are offering :)
email addy is stuandjan <at> xtra <dot> co <dot> nz
Stu
PostPosted: Tue Jun 14, 2005 11:14 pm
Pete
The instruments are the same as in any clubman just the warning lights seem mto differ. Did the poms use the same type of instruments? BTW Gavin I will PM you my email address.
Chris
