It is currently Sat Jul 19, 2025 12:16 am
 Post subject: Remote shifter hole
PostPosted: Sat Dec 17, 2022 7:54 pm
Putting a remote shifter into an 850. Anyone got any measurements or even just a photo?
 Post subject: Re: Remote shifter hole
PostPosted: Sat Dec 17, 2022 8:44 pm
56 cm to 65 cm from the passenger door sil
4 cm to 16 cm forward of crossmember
I would cut it a bit smaller to start with then test and adjust as needed
56 - 65 cm from the passenger door sil. 4 - 16 cm forward, Remote floor hole.png
PostPosted: Sat Dec 17, 2022 8:57 pm
Thank you so much.
PostPosted: Sun Dec 18, 2022 8:58 pm
How difficult is it to fit a remote shifter in an 850 with a RC40, while keeping the starter button?
PostPosted: Sun Dec 18, 2022 10:01 pm
Have the remote shifter, RC40 (1&7/8?) and 850 push button start in my Monaco which is based on a 62 850.
Made sure the battery cables had the lugs on the best way to keep them away from the exhaust.
No problems with it.
PostPosted: Mon Dec 19, 2022 8:05 am
I had to give the exhaust pipe a bit of a hit with the hammer to give clearance. With the exhaust tucked up a bit more it had made contact before I added the divot
