It is currently Wed Jul 23, 2025 3:19 am
 Post subject: Which Oil
PostPosted: Mon Apr 17, 2023 9:54 am
Probably been covered many times but opinions change as do oils.
So which oil do you use in your Mini and why?
Cheers Dave.
 Post subject: Re: Which Oil
PostPosted: Mon Apr 17, 2023 10:14 am
Gulf Western 20W50.
Because gives better pressure when hot, some folks even race with it.
Has plenty of zinc in it for our flat tappet antique motors.
Cheap when on special at supercrap,
Yes I have used penrite, castrol edge 25w50, valvoline XLD, etc etc before.
It's on club rego, it gets an oil change and wix filter once a year, or sooner if dirty.
PostPosted: Mon Apr 17, 2023 1:44 pm
I am running 15w40 diesel oil as it is an auto and the additives in petrol oils are bad for the automatic transmission. The diesel oils are also often rated to an Allison auto spec and is a lot cheaper than the commonly recommended MA2 motorbike oil.
I know it is not very useful info for someone with a manual but there are often auto owners who don't know so if one sees my comment it is good.
Test... Don't Guess
PostPosted: Mon Apr 17, 2023 1:54 pm
Gulf western, Valvoline XLD or Penrite when on sale. Good pressure and stability at high temps
Castrol GTX was no good as it gave low pressure and drop gear knocking
PostPosted: Mon Apr 17, 2023 4:40 pm
Thanks all just the ticket.
Can I ask which gulf western 20w50 as there seem to be 3 or 4 choices, xmp, hvx etc.
Cheers Dave.
PostPosted: Mon Apr 17, 2023 4:57 pm
XP or XMP
PostPosted: Tue Apr 18, 2023 9:01 am
gtogreen1969 wrote:
XP or XMP
Just for those following along at home - this was in 2018.
Please note that the opinions in the below image are not my own, use the 15w50 at your own prerogative. (just noting the difference between the XP or XMP)
Nick
PostPosted: Tue Apr 18, 2023 9:43 am
Also a Gulf-Western fan.
;-) Pete...
____________________
1968 Deluxe 1275
1969 Deluxe 'Scruby' 998 Looking for a roof skin...
PostPosted: Thu Apr 20, 2023 5:26 pm
Penrite HPR30 all day, every day for me. Along with really frequent changes.
PostPosted: Thu Apr 20, 2023 11:17 pm
HPR30 Pentrite.
PostPosted: Fri Apr 21, 2023 6:43 am
Yes Penrite HPR30. Have been using it since 2003 and also do frequent changes along with filter.
PostPosted: Mon Jun 05, 2023 7:52 pm
Is Valvoline XLD Premium API SL/CF ok, or needs to be the XLD Classic API SG/CD ?
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Jun 18, 2023 10:52 am
I've been using Penrite Classic Mini 20W-50. Penrite states it has high zinc levels but doesn't mention how much.
The Penrite HPR30 20W-60 says it has 1600ppm of zinc.
Is there any benefit of one of these over the other for a general driver 850?
Thanks Rocky
PostPosted: Sun Jun 18, 2023 6:07 pm
Thanks Rocky
The Classic Mini oil doesn't get a mention, but this chart is useful for looking at ZDDP content of Penrite products, something a lot of other manufacturers don't share
https://penriteoil.com.au/knowledge-cen ... mmary/1035
PostPosted: Sun Jun 18, 2023 6:57 pm
That's a really good chart Ben - thanks for the link.
I'm going to get in touch with Penrite tomorrow and ask them for the zinc ppm in the Classic Mini oil. I'll post whatever I find out.
Rocky
