It is currently Fri Jul 18, 2025 1:56 am
PostPosted: Sat Nov 25, 2023 12:24 pm
I recently purchased a Rover style boot seal that attaches to body (CKE10018) and I'm having some issues trying to close the boot.
Not sure if its just the rubber being new or whether it straight up doesnt fit my 69 Mini K
According to Mini Plus website, the seal should fit all minis https://www.minisplus.com.au/classic-mi ... ll-on-body
thanks in advance
PostPosted: Sat Nov 25, 2023 3:20 pm
According to Minisport SA that boot seal is meant for 1988 to 2000 models i.e. UK models.
I'm not sure if they should fit an Aust'n mini but they appear to use pinchweld to hold the seal in place, which becomes a fairly thick lump to be compressing to get the boot lid closed.
The original seal goes on the boot lid and closes against the flange on the boot opening but with only a light pressure. I think the Rover one is too thick to work the same way.
The seal that fits to the boot lid (14A6584) is more expensive but they seem to last forever. I have one on my mini K.
And, don't bother using the little clips to fit that seal - just use contact adhesive. MiniSpares website has advice on orienting the seal correctly.
PostPosted: Sat Nov 25, 2023 3:32 pm
thanks in advance
It is possible that this one would be a better buy.
https://rubbersealsaustralia.com/produc ... seal-mini/
PostPosted: Sat Nov 25, 2023 8:44 pm
There is no difference in the bodies so it will fit as well as it does to a Rover.
Test... Don't Guess
PostPosted: Sat Nov 25, 2023 9:25 pm
Hi, I have one on my mk1 cooper S and it fits but it's definitely hard to close the boot and lock the latch.
This is only temporary until I fit the correct one, one of those tomorrow jobs I'm not looking forward to.
Rgds Stewart
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
PostPosted: Tue Nov 28, 2023 9:46 am
I have a rover boot seal on my Deluxe - no problems at all with it fitting.
The seals can be tight when new till they settle a bit.
PostPosted: Tue Nov 28, 2023 1:14 pm
Thanks for everyone's replies... decided to order in a boot mounted seal + clips. Already have a swear jar ready for the install haha
PostPosted: Fri Dec 01, 2023 11:11 am
ditch the clips and glue it on...
PostPosted: Fri Dec 01, 2023 1:49 pm
To install the clips what I found works best is a tool with a 90 degree end. It means that they can be pushed straight in, not on an angle.
This is what I used.
Test... Don't Guess
PostPosted: Sat Dec 02, 2023 8:05 pm
I followed this procedure and it worked very well.
viewtopic.php?f=2&t=49338&hilit=boot+lid+seal
PostPosted: Sun Dec 03, 2023 9:41 pm
Took my time installing the boot seal with clips, following Cafe Racer Labs very helpful video (linked below).
Maybe I expected worse, but it really wasnt too bad. Some of clips took 3 or 4 attempts and had pliers slip onto the paint once or twice nothing major.
Boot closes (unlike with the rover seal), but its still a bit of a struggle... imagine this will get easier as the rubber compresses.
https://www.youtube.com/watch?v=_ysRnNpxFjY
PostPosted: Sun Dec 03, 2023 10:47 pm
It will be difficult to close at first like you have found (I used to have to lean on mine). After a while it will be easy.
Test... Don't Guess
