It is currently Thu Jul 10, 2025 9:24 am
 Post subject: ENGINE RPM
PostPosted: Sun Apr 28, 2024 10:34 am
When I put my finger on this hole to block it off the engine revs rise, is this normal?
 Post subject: Re: ENGINE RPM
PostPosted: Sun Apr 28, 2024 11:15 am
I think that just allows the top of rubber diaphragm in the PCV to regulate to atmosphere pressure. There shouldn’t be any air coming in or out under normal operations, it could mean the rubber diaphragm is split or incorrectly installed
There’s a sectional drawing of the pcv on the site below, there shouldn’t be any air getting on top of the diaphragm
https://mgaguru.com/mgtech/engine/cv103.htm
PostPosted: Sun Apr 28, 2024 1:05 pm
The rubber diaphragm is new and in good condition and PCV is put together correctly. I can feel air coming out of the hole indicated and when hole is blocked by my finger rev's increase.
PostPosted: Sun Apr 28, 2024 1:51 pm
Do you have a vacuum pump of some kind?
If you were to connect both fittings to a vacuum source they should not leak down. If they do then the diaphragm is leaking.
Too many minis
