It is currently Mon Jun 17, 2024 6:50 pm
 Post subject: Flare width
PostPosted: Sun May 26, 2024 7:59 am
Hi All
I have just replaced the step, sill and part of the floor panel on my S on the drivers side and want to put on wider flares to ensure I am compliant with NSW regulations on tyre coverage. I cannot seem to find flares of the right width for me that will also take the side trim,(2.5 inches) so that the tyres are covered, but the flares do not stick out too far. Can anyone tell me the width, from the mudguard, of the competition flares that are available from minisport?
BMC MINI WIDE COMPETITION FLARE SET- HYL3942 KIT
Bazzz
Mini Cooper S Mk 2, 1970,
Mini van 1970 with side windows now converted to 4 seater traveller
 Post subject: Re: Flare width
PostPosted: Sun May 26, 2024 10:53 am
I got some Group2 race flares from OldSkool Minis to cover my 6 x 10 chromed Minators, they have a lip on them for the strip if you want to fit it but with my wheels this made the flares stick out too far above the wheels. So I cut the lip off the flares and the edge of the flare now lines up exactly with the side of the tyre. With the lip the flares were 80 mm wide at the front and 75 mm at the rear.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sun May 26, 2024 1:03 pm
If no-one can answer this I suggest you call Minisport and ask for the width of the front and rear backing strips at their mid-point.
https://minisport.com.au/products/bmc-c ... s=e&_v=1.0
PostPosted: Tue May 28, 2024 7:31 am
Thanks Wannabey and slide for your advice. I have found these Mini 'works' copy fibreglass flares set, can keep original chrome side strip (screw on) 2.5" wide at Minisport (C-STN71) that look like they may solve my problem. Can anyone recommend them?
PostPosted: Tue May 28, 2024 12:09 pm
I haven't fitted them to a car and just personally I wouldn't as they are fixed by screws into the side of the guard, a potential rust spot. Unless you are replicating a BMC Works rally car the wide BMC Australia competition flares with the metal backing strip are a much better option in my view. They retain the original style chrome side strip (see the picture of Rocky Canto's Bathurst car in the advert).
https://minisport.com.au/products/mini- ... s=e&_v=1.0
PostPosted: Tue May 28, 2024 2:00 pm
Agree Wannabey about the rust, and also the image on the Minisport site shows them coming over the front bumper. However Minisport have just got back to me and the Competition flares are 3" wide and that extra 1/2 width compared to the fibreglass ones could make the flares look oversized which I think is not a good look. A dilema.
