It is currently Mon Jul 14, 2025 9:38 pm
PostPosted: Wed Jul 09, 2025 12:36 pm
I've recently had the head machined, and just about to reinstall the head but before I do wanted to check on a couple of things.
I dropped the oil before removing the head (probably not needed in hindsight), and so I'm conscious of potential issues with getting oil pressure thru the pump. Do I need to anything specific to prime the oil pump? I have seen recommendations to crank without the spark plugs for 30/40 seconds until pressure shows on the gauge.
Also, should I pour a tablespoon or so of oil into the chamber before reinstalling the head to give the rings some initial lubrication?
PostPosted: Wed Jul 09, 2025 6:52 pm
No forget the oil pump, unless it's been standing for a year or more. Just crank it with plugs out until you get pressure.
You can put a spot of oil in first, won't hurt, but not necessary.
Retighten the head and adjust the valves when hot.
I would repeat after 500-1000 miles.
PostPosted: Thu Jul 10, 2025 8:42 am
Thanks DrMini. Really appreciate it.. just wanting to do things right first time
