It is currently Fri Jul 18, 2025 12:50 pm
 Post subject: Sway/ anti roll bar.
PostPosted: Tue Jul 08, 2025 8:56 pm
Firstly is a sway or anti roll bar of any benefit on a road car and what is its purpose and effects.
Secondly to identify what type. An angle iron frame bolted across the rear of the rear subframe and along each side member. The bar is attached to the frame with rubher mounts with, from what I can tell are rods attached to the bar and then the bottom of the hubs somehow. I tried to take photos but I will need to hoist the rear to get a good one.
Any ideas appreciated.
Cheers Dave.
 Post subject: Re: Sway/ anti roll bar.
PostPosted: Tue Jul 08, 2025 10:08 pm
My first MK2 S had K-mac (hydrolastic) front and rear bars when I bought it in 1976, installed by previous owner (original owner). My current resto MK2 S did have holes drilled in the rear subframe for a rear bar, though not fitted. I am installing Selby dry suspension sway bars on this car, having made brackets for the rear arms per pics below. K-mac bar on original car had pressed steel brackets mounted on rear bump stop bolt, with links dropping down to bar. Use of a rear anti-roll bar increases roll stiffness, therefore helping reduce understeer apparently.
PostPosted: Tue Jul 08, 2025 10:51 pm
Dave, a “sway bar” (aka roll bar) is basically a torsion bar that transfers load diagonally across the car. Ie a rear bar transfers load (and so grip) from the outside rear wheel to the inside front wheel… which is why people usually fit a rear bar to Minis …. to load the inside front wheel to reduce understeer by increasing front end grip. Having a bar at each end just complicates things..
Most of them are round section ..like the set I bought at Selby’s Sydney MotorShow stand in ‘76 for my Golf. but there’s no law that says they have to be….
Get a case of beer and we can discuss the fine print.
Cheers, Ian
PostPosted: Wed Jul 09, 2025 11:13 am
Cheers, Ian
Thanks for the great explanation, makes it really clear. I already have the beer. ;-)
Mine looks nothing like the ones ausdino has shown. Will try for better pics.
Cheers Dave.
PostPosted: Wed Jul 09, 2025 2:53 pm
Theoretically the sway bars don’t change the way the suspension works when you’re driving straight with no load on the suspension
When you add load, like around a corner the sway bar effectively adds stiffness like you’ve got a stiffer cone/spring
With a classic mini, normally a sway bar is added to the back end, and the stiffer effective suspension reduces the rear grip, in turn reducing the amount of understeer.
PostPosted: Tue Jul 15, 2025 7:06 am
Sorry a bit late to the party, but thought i would chime in with a possible ' road version' caution.
The info above is a very good explanation of the effects -
the action of either reducing front understeer or actually increasing oversteer by letting the rear hang a bit is exacerbated in the wet.. In just about every case I know in a wet race setting - teams either loosen up the rear sway bar or disconnect it due to the much higher probability of doing a pirouette ( losing the back) There is practically zero warning . No idea of whether spirited road driving in wet conditions would trigger that scenario - but i thought it worth a shout out.
PostPosted: Tue Jul 15, 2025 7:30 pm
Pretty sure I have a set of KMAC brackets for dry suspension if anyone is interested.
PostPosted: Tue Jul 15, 2025 9:17 pm
I just reread the “Suspension” chapter of David Vizards, How To Modify Your Mini.
His recommendation is to maximise the grip of the front suspension first (you will need adjustable suspension components to do this) and if this does not reduce understeer enough, then perhaps fit a rear anti roll bar.
Regards
Phil
