It is currently Wed Jul 30, 2025 6:14 am
 Post subject: Brake overhaul
PostPosted: Sun Jun 05, 2005 6:28 pm
I am stripping and rebuilding my disk brake setup. Just wondering what I should be replacing. Brake hoses and new pads are a must but what about the pistons? is there a kit you put in them?
Thanks
PostPosted: Sun Jun 05, 2005 7:09 pm
Yes there's a seal kit of fluid seals and dust seals.
Wire brush the pistons when they're out. If any flaking chrome/rust on the outside, bin them and buy new. You can get S/S ones but chromed ones (like original) are cheaper and will last over 20 years anyway.
If you split the calipers always replace the little seal between them. It's not in the seal kit.
PostPosted: Sun Jun 05, 2005 11:22 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i got ss pistons from burt brothers on fairfield rd fairfield 3 years ago for about 15 bucks each
makka
PostPosted: Mon Jun 06, 2005 7:01 am
Chrome ones (stock) are $15.97 ea
S/S ones are $27.45 ea.
At Karcraft.
S/S ones are Bling! (can't see 'em though!) but the chromed ones are harder surface. Your choice. I run a set of each in out 2 cars... :wink:
PostPosted: Thu Jun 16, 2005 10:08 pm
Got all the gear from Karcraft during the week. I replaced my ball joints according to the manual. Should I be able to move the ball pin by hand once they ar all tightened up? because mine are solid!
Can someone give me a laymans guide to fitting them. And if your not busy include a run down on replacing the pistons as well. Thanks
PostPosted: Thu Jun 16, 2005 10:26 pm
If your balljoints are solid, you need to add more shims. When it's right, you should just be able to move them by hand with the big cap nut done up to 72lb/ft. Don't forget to do up the lock tabs... :shock:
To get the caliper pistons out, take caliper off hub, put a clamp on the inner one and apply low pressure air to eject the outer piston.
The inner one can be removed with a pin punch through the hose fitting hole.
Some people (masochists) fit seal kits without splitting the caliper. I always split them, it makes it so much easier.
Remove the old dust seal and fluid seal using a small screwdriver, don't scratch the bore or the seal groove.
Wash it all out with brake fluid.
Pop the new fluid seal in with your fingers, lube it with brake fluid.
Fit the piston in leaving 8mm sticking out.
Fit the dust seal into the metal ring and carefully push it into the groove, keeping it square. I use a suitable socket to drift it in. Don't hit it hard...!
Push the piston in flush.
Repeat above steps for other 3 caliper halves.
Replace the fluid seal between halves with a new one, and bolt back together.
There! easy, wasn't it... :wink:
PostPosted: Thu Jun 16, 2005 10:32 pm
Thanks Doc
PostPosted: Fri Jun 17, 2005 9:08 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
bromley i can attest to it being that easy just one thing dont do what i did when you put em back on the car ... put the right on the left and the left on the right you wont get them to pump up :roll:
it took me a while trying to work out what was wrong then i seen it the bleed nipples were at the bottom nothing but air above doh :oops:
makka
PostPosted: Sun Jun 19, 2005 10:48 am
Yea, it wasn't a hard job at all. The problem is that I pressed one of the metal seals in awkward and its bend up slightly on one side. It doesn't pop out or move because of my hack job with a screwdriver to get it in.
Is this going to be alright - or should I go and spend more money on another kit?
