It is currently Wed Jul 30, 2025 7:31 pm
 Post subject: Upper arm problems
PostPosted: Mon Jun 20, 2005 5:09 pm
Today I tried refitting my upper suspension arms to the subframe. I encountered a problem whereby I didn't have room to fit the arm in with the suspension cone in the nylon cup.
I haven't compressed the rubber cone like the manual says - I imagine this is my problem but thought that If I could get the arm out with no hassles I could get it in with none either.
Is there a way I can do this without needing the compression tool? Any advice will be greatly appreciated!!!
PostPosted: Mon Jun 20, 2005 5:33 pm
I'm guessing no the old rubber cone was easier to get out cause it was old and the weight had compressed it over time.
it is not too difficult to make a cone compressor
some flat thick steel, some threaded rod (nice and strong so good grade) and a couple of nuts to suit the rod was what we used forr mine.
There are two different thread sizes for the rubber cones so be care to select the right thread size. The link below has the thread sizes and lets you know the appropriate dates
http://www.minimania.com/InvDetail.cfm?Item=660330
Roads need more corners
PostPosted: Mon Jun 20, 2005 10:14 pm
If i were you, i`d simply buy a set of "Hi-Los",,,these are simply adjustable struts,,,well worth the $ & easy to fit & then you can adjust your ride heights to being nice & even all round.
& BTW, i fit the whole std un-adjustable system """without""" the cone compressor,,,it is a bit difficult, but very do-able,,,done it many many times, BUT!!! i`ve seen guys usine the cone compressor smash/squash their fingers when the thread strips out rather suddenly
OUCH!!!
Buy the Hi-Los & be done with it,,, easy-peasy...& Piece of cake,,,you won`t regret it,,,imagine fitting all your stuff in there & the car sits on an angle,,,or subsides & lists to one side after a little while driving it,,,yeah, YUK!!!,,,Oh that`s right, you were really smart & fitted Hi-Los,,ha ha,,,easy,,, you can simply adjust it easy-peasy ,,,Yeah???? :-)
be smart :-)
PostPosted: Mon Jun 20, 2005 10:43 pm
LOL mini man your the best! :D
Lillee - 1969 Morris Mini K
PostPosted: Tue Jun 21, 2005 11:29 am
Yea I have considered the high low option, where are the best ones/place to buy them from?
