68matic wrote:
these are reasons to your brake problems that i know of:
3. brake adjustment: there are two adjusters on the front wheels. i adjusted mine once such that they were way too loose and the brake pedal gave in easily. i then tightened them, and the brake pedal was way too hard. you need them just right.
it takes a while to figure them out by yourself
Took me 3 months to figure it out. I was adjusting them so that the shoes were just missing the drum... eg no scraping sound when you turn the drum and the pedal would go straight to the floor no matter what I did.
As soon as I adjusted it so there was just a little bit of scrubbing.... so the shoes were just touching the drum in their 'off' position the peddle came up straight away.
dewey
