It is currently Fri Jul 18, 2025 11:18 am
 Post subject: power boost?
PostPosted: Sat Mar 27, 2004 7:03 pm
hello,
i have a stock standard 1100 motor,it has been re-cod' or so the previous owners said,and it has a didgy little 1 1/4 SU that is out of tune on her,but the thing is,iv saved up enuff cash to buy a LCB manifold,2" exhaust to a rezinator and twin chrome tips at the arse,should look cool, and a pair of twin 1 1/4 SU's on stoc manifold,once i get all that on,im gunna take her to a dyno tuner(more power) and have it all tuned to the motor,will these mod's give me much of a power increase over what the motor is doing now?i hope it will but im realy not sure,plese help me
PostPosted: Sat Mar 27, 2004 8:57 pm
just sell it and buy a matic m8 ROFL, nar heavy cam it i rekon
12 Months ?????????????
PostPosted: Sun Mar 28, 2004 5:56 am
I wouldn't go over 1"3/4 for the exhaust size. Straight through lukey mufffler. The LCB extractors on an 1100 are a bit of an over kill. Expensive and don't work any better than standard S type extractors for a road engine.
I would: Change exhaust. S extractors, 1 3/4 system
Fit a single 1 1/2 or twin 11/4 Su
Forget about dyno tuning.
Bob
PostPosted: Sun Mar 28, 2004 6:17 am
I'll disagree with Bobtel on this one- I've found an LCB works better on 1100 than a freeflow does, IF you have a cam and headwork. :wink:
I'd do both before these you worry about carbs or dyno.
Don't go too big on cam- a 270 duration is as far as I would go with these.
As for carbs, You can't beat twin HS2s on an 1100... :P
