Update:
Hubnut is off (****** tight bastard that one!) steering rack is disconnected but having massive problems with the upper and lower ball joints!
Already bent my ball joint splitter tool trying!
Not sure if I should get the fork type splitter. Aaron and Doc, what do you recommend? I've WD40'd her to death, wacked the top ball joint hard several times, tried levering, tried jacking her up from the brake hub and wacking the bottom arm off, all no good. Got tired and serviced the carb instead
Will try my cousin's BFH tommorrow and see if it pops out. Otherwise off to Ivan and Gareth at Castle Hill
Managed to fix everything else other than the Pot Joints this weekend so she's looking good elsewhere
