Flat Hydro Bag = resting on the bump stops (the whole weight, not good.) If you don't have bump stops, top suspension arm meets subframe, not good, not good at all!!
With much lower hydro pressure, you will have no handling to speak of, and the bumpstops won't last long.
If you want to lower it a little, you might get 1/2 an inch before the pressure starts to get too low.
My opinion is, don't mess with the hydrolastic setup pressures too much. Hydro bags are getting older and harder to source good ones.
Go the Hydraulic rams and rubber cones route. You can even run the hydraulic lines where ther hydro pipes used to go...
I don't mind taking those old hydro bags when you pull em out....
