G'Day Matt,
Inlet manifold should be under vacuum so will not blow bubbles. Thats how you check exhaust and BBQ gas cylinders are not leaking - with soapy water (not matches)
I would think if wd40 is getting in in sufficient quantity watch the exhaust for white smoke. (Popemobile?)
I did have a problem with regularly chewing up the large bore manifold gasgets and getting air leaks when it fractured. I was told the material they are made out of is (insert unflattering comment). Lucky for me I still had the machined grooves in the head for the locating rings and was able to use the standard, ordinary, plain, regular metalised manifold gasget and no problems since. That was 3 years ago and have not even had to re-tighten the (brass) nuts. They ARE brass arn't they?
