It is currently Mon Aug 04, 2025 1:53 am
 Post subject: Engine Capacity?????
PostPosted: Tue Jul 26, 2005 6:11 pm
Ok I was just wondering what size the engine capacity goes to once bored out to certain thousands of an inch
eg: 850 .020" = ........
.040" = ........
.060" = ........
etc,etc,etc
Just out of curiousity
the doc might (probaly) would know
Pat
_______________________________________________
Team MADMAN/Pat Rogers
PostPosted: Tue Jul 26, 2005 7:06 pm
i just worked these out so not sure how correct they are
850 is actually 848cc
+20thou = 863.3cc
+40thou = 877.2cc
+60thou = 891.2cc
998
+20thou = 1015cc
+40thou = 1030.4cc
+60thou = 1046.5cc
1098
+20thou = 1115cc
+40thou = 1132cc
+50thou = 1141cc (thas what mine is)
+60thou = 1152cc
if you want any more ill calculate them for u :wink:
PostPosted: Tue Jul 26, 2005 8:11 pm
For a 1098 you can now get +.080" Hypatec flat tops again. Lovely... 8)
These will give you 1162cc.
Graham Russell has them. :wink:
PostPosted: Tue Jul 26, 2005 8:44 pm
Any idea on price for them Doc? Would they be suitable for a turbo buildup?
PostPosted: Tue Jul 26, 2005 8:53 pm
I wouldn't think thatit would be wise to run a turbo because at that capacity the walls of the bores would be to thin and I wouldn't like to be there when it blew up
Hey ben what is the bores for a 1275cc?
Pat
Sorry no idea on price really, & for turbo the C/R would probably be too high. You need some nice dished ones... :wink:
PostPosted: Wed Jul 27, 2005 9:31 pm
So I'll just bump this up here. Hopefully find out what the capacity would be for a 1275cc engine that has been bored out 20,40,60thou and so on if anyone knows
Pat
PostPosted: Wed Jul 27, 2005 9:43 pm
+0.020" = 1293
+0.040" = 1310
+0.060" = 1330
bore to 73mm = 1360
bore to 73.5mm = 1380
bore to 74mm = 1400
edit: assumes std stroke.
Steve
PostPosted: Wed Jul 27, 2005 9:49 pm
And the 74mm ones appear to be unobtainium now. :cry:
Steve you forgot 74.7mm, (Triumph 2.5PI) 1426cc... 8)
Block's getting a bit thin, isn't it...
PostPosted: Thu Jul 28, 2005 8:05 am
Very thin may even break into the oil ways.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
