It is currently Wed Aug 06, 2025 2:58 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Wed Aug 03, 2005 1:04 am
Theyre called a "dB Meter".
The professional ones that are properly calibrated cost way too much to even think about.
I have a hand-held one that cost about $100 from Dick Smith Electronics... I use it to find the resonant frequency of car stereos used in SPL competitions..... but mine can only be used at low volumes. It only measures up to 130dB.
PostPosted: Wed Aug 03, 2005 1:36 pm
i think mine is about 120db. LCB 2in and a stupid cannon. but the webber is stil louder
PostPosted: Wed Aug 03, 2005 2:47 pm
supercharged 850 wrote:
low volumes
130dB.
i think you need your heading checked mate :)
PostPosted: Wed Aug 03, 2005 3:56 pm
Supercharged 850 is a ICE nut: " you need your head checked mate :) "
PostPosted: Wed Aug 03, 2005 4:16 pm
"You need your headunit checked, mate"
It should be :lol:
PostPosted: Wed Aug 03, 2005 7:55 pm
Got told a trick by the inspectors at ViC roads when I worked their. Steel wool up the exhasut pipe doesn't restrict the airflow to much and cuts the nose down! You pass the test and it just burns out in a very short time! Haven't tried it but they seemed to know all the tricks!
PostPosted: Thu Aug 04, 2005 1:11 am
low volumes
130dB.
Geez... I was just pointing out that I have a dB meter.... then said that it was bought for car audio applications.... then I said that it only went to 130dB maximum... which is not enough for my stereo. (I need something that measures up to 150dB or more to get a proper SPL reading, but the handheld can find resonant frequencies at ANY volume)
It IS good for measuring exhausts, and has been used for this purpose too.
