It is currently Sun Aug 10, 2025 10:52 pm
 Post subject: Brake bleading issues.
PostPosted: Wed Aug 17, 2005 10:08 pm
hey guys.
I'm just having a bit of trouble with my brakes, the pedel is fairly squishy so the other day I decided i would blead the system. On the backs i could only get a trickle of fluid to come out, and i couldn't push the pedel to the floor with the blead nipple undone. it was the same for both sides.
when i did the fronts, i could get a lot more fluid out and the pedel would go all the way to the floor.
what would cause so little fluid to come out of the rears? i certainly don't think this is normal, but correct me if i'm wrong.
Cheers, Cazmo
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Wed Aug 17, 2005 10:17 pm
limiting valve on the rear subframe.
I have a good bleeding method posted on my website forum. I can't be bothered retyping it..... :?
PostPosted: Wed Aug 17, 2005 10:39 pm
Check your rear hoses, trust me I just did mine and the Doc was right the left had closed up tight with age :evil:
PostPosted: Fri Aug 19, 2005 9:13 pm
how much would one of those limiting valves be worth?
PostPosted: Fri Aug 19, 2005 11:57 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
caz i would go the pipes first they would be the likly problem if they are old
makka
PostPosted: Sat Aug 20, 2005 12:09 am
Total agree...with Makka and Woffman...but I would then check the Limiter..its time to get a couple of bottles of brake fluid mate :wink:
PostPosted: Sat Aug 20, 2005 7:03 am
Don't think you can buy the rear limiting valve now, Karcraft don't list the Lockheed seal kit for it any more either. :cry:
PostPosted: Sat Aug 20, 2005 1:30 pm
The problem will be the rear hoses,,,
it`s nearly allways the rear hoses,,,
the pressure limiting valve hardly ever stuffs up,,, & even if it did, normally it would just not work, but would still allow fluid to come through
Replace both your rear hoses & bleed it all again & you should be fine
Point of warning tho!!!!!!!!!!!....If you go to bleed the front, --->you`ll need to "UN-ADJUST" them,,,then bleed them & then "ADJUST" them back up to do it properly,,,that is unless you have front disc brakes, then just happilly let them gravity bleed away :-)
easy-peasy :-)
PostPosted: Sat Aug 20, 2005 11:50 pm
Thanks guys,
I'll changes those rear hoses, re-bleed and see how it goes.
Users browsing this forum: No registered users and 119 guests
