It is currently Sat Aug 16, 2025 2:09 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
HS4 or 45DCOE?
45DCOE 75%  75%  [ 15 ]
HS4 25%  25%  [ 5 ]
Total votes : 20
PostPosted: Thu Sep 08, 2005 10:39 pm
Nope :lol:
And cushy... **** off or once?
You don't start any posts buot mini stuff... cos ur mini is ****** cactus.
And you won't do anythign about it.
cos ure lazy as ****** anything.
PostPosted: Thu Sep 08, 2005 10:49 pm
you should do a www.cush.com in retaliation
PostPosted: Thu Sep 08, 2005 10:52 pm
hmm, cool site
PostPosted: Fri Sep 09, 2005 1:12 am
I haven't started topics about mini stuff recently because I'm quite learned in the use of the search function. And I haven't had the need to ask about anything for a while because I don't feel the need to ask a question or an opinion everytime I hear the words "x percent peformance improvement" or when I start seriously thinking about considering buying a new part, maybe. See www.willy.com for more details.
Well. I'd hardly call a bung throw-out bearing cactus. :?
And I'm not doing anything about it because I've been told not to.
William, one day, when you work the hours that most adults do, including mechanical workshop owners, you'll realise that you'll just pop down to the mechanics during your double free in the morning, before your applied mathematics and english as a second language lessons, like you could at Norwood Moriyatla.
I think it's time for a poll :) Hands up those with minis that aren't running.
PostPosted: Fri Sep 09, 2005 4:20 am
ME-ME-ME I'm in that catagory too cushy
67' Matic
73' S
PostPosted: Fri Sep 09, 2005 11:05 pm
great.... i'm gald to have the big guns behind me :)
PostPosted: Sat Sep 10, 2005 10:52 pm
Yer, mines not going 'broom broom' right now. :cry:
PostPosted: Sun Sep 11, 2005 10:10 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i got two that dont run :(
but it is cos i really am lazy
BAAAAAAAAAAAHAHAHAHAHAHAHAHAHAHAHAHA
makka
PostPosted: Mon Sep 12, 2005 2:07 am
me too makka :(
but I'm not ashamed :P BAAAAAAAAAAAHAHAHAHAHAHAHAHAHAHAHAHA
67' Matic
73' S
PostPosted: Tue Sep 13, 2005 2:20 pm
Go the HIF44 on any motor small er than 1293 or even 1310.
this carb has seen over 140 HP on many mini miglia and even on GR's 1400 stroker it made as much power as other same size motors on the dyno day.
my turbo would be making over 140hp and its a HIF44 (turbo version HIF6)
great carb, he rolls royce of carbs
100% Pure A Series Turbo
PostPosted: Tue Sep 13, 2005 4:11 pm
can you use the turbo special carb on na motors?
PostPosted: Tue Sep 13, 2005 4:39 pm
sure can but they are no different to the n/a carb apart from a pressurised float bowl and throttle linkage set up.
PostPosted: Tue Sep 13, 2005 6:03 pm
can you convert a standard carb to a pressurised float bowl
PostPosted: Tue Sep 13, 2005 7:02 pm
i think burlen has a kit
http://www.burlen.co.uk/partDetail.aspx?partID=2147
:P
