It is currently Sat Jul 19, 2025 3:18 am
PostPosted: Sat Aug 21, 2004 10:46 pm
Every 2nd Mini I've bought had the remains of a locking cap inside the tank.. :lol:
Almost as common as finding the filler neck lugs or the neck top shagged.. :cry:
PostPosted: Sat Aug 21, 2004 10:52 pm
I have never come across it B4 :shock:
But I had to Laugh...Then I took the Fuel filter off and it was black...I had to shake my head..no wonder Marcia was not running well.
You always find funny things when your stipping a car down always a few surprises
PostPosted: Sat Aug 21, 2004 10:55 pm
Anyone know how to get the tumblers out of a Deluxe / S door handle??
If I remember from when I had to change a broken handle on my deluxe,you needed to have it unlocked before you could get the barrel out.I think there is also a pin that needs removing.
PostPosted: Sat Aug 21, 2004 11:03 pm
Thanks! It's unlocked already. None of my keys fit. I know if I drive to Mudgee I can get some keys- my mate has oodles of them. :idea: Hey there, any key hoarders this side of Mudgee?? :P
PostPosted: Sat Aug 21, 2004 11:28 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
Kev aparently from what i heard last night aussie door's were differnt to pommie doors BUT sarth arfrican and ewe zealund doors are the same ....
we exported our doors to them i found this out from Alan Foy was with bmc and blmc from 57 till 75 76 he new of the mini in 58 they had a mini for r&d from late 59 ...... very interesting man some were bored but the infomation he had was amazing talked about the r&d that went into the mini the freeway and others of the time
btw this was last night at the restorer's meeting and was also talking about the histerical society get together at granville i'll let you know more as i know
makka
PostPosted: Sun Aug 22, 2004 6:57 am
Makka, I know our doors are different, but they all had Pommy `Union' lock tumblers and keys back then..
If they don't fit, too bad. :cry: Nobody could tell me if these ones currently available fit so f**k it, I brought some in to try.. :lol:
PostPosted: Sun Aug 22, 2004 8:42 am
:? OK a search of some manuals have given me the following two explanations. Neither of them make any sense to me though... but may help others.
Removal of the front door lock assembly
1 Remove the door interior trim panel.
2 Undo and remove the screws securing the door inner remote control handle to the door
panel.
3 Undo and remove the screws securing the interior lock control to the door panel
4 Undo and remove the screws securing the door lock to the side of the door
5 Slide the door lock out of its location in the door and carefully release the two small
circlips securing the remote control handle and interior lock operating rods to the door
lock assembly.
6 Lift away the door lock, then withdraw the remote control and interior lock control from
the door panel.
Removal of front door exterior handle
2 Undo and remove the screws securing the interior lock control to the inner door panel.
3 Undo and remove the screws securing the door lock assembly to the side of the door,
and move the lock up at the bottom and away from the door.
4 Undo and remove the screws securing the exterior handle to the door and lift the handle off
With the handle removed, the lock barrel and push button can be withdrawn as follows:
5 Prise off the retaining clip securing the lock barrel to the handle.
6 Insert the key into the lock and withdraw the lock barrel.
8 Undo and remove the screw securing the retaining plate to the exterior handle.
9 Lift off the retaining plate, operating link, washer, and spring. Now withdraw the push
button.
PostPosted: Sun Aug 22, 2004 9:40 pm
8) I scored some NOS Clubby door locks with key for $10 today. Thats $10 for both!
 Post subject: Locksmith
PostPosted: Mon Aug 23, 2004 5:33 pm
If you are after a locksmith-for cars, try
www.innerwestsecurity.com
(02) 9660 1811
107-113 Booth Street
ANNANDALE NSW 2038
No I don't work for them, but they helped the wife one day in the Triumph (and got me out of trouble for a few weeks!)
Wazza
PostPosted: Mon Aug 23, 2004 7:41 pm
Wazza..!! If you are recommending them I will try them. They are about 100 meters away from home...
:lol: <<laughing.
