It is currently Sat Jul 19, 2025 3:10 am
 Post subject: nut on clutch housing
PostPosted: Sat Aug 28, 2004 2:40 pm
the nut and cap
that are on a threaded thing
on the left of the engine, clutch housing i believe, are a little loose.
the whole assembly (nut, cap, thread) are tight together, but all can move about 20 degrees
is this a problem
thanks
the engines a 1100 clubman
Inconspicuously Conspicuous
PostPosted: Sat Aug 28, 2004 2:43 pm
That is NORMAL. The plunger has some rotational clearance on the clutch lever arm's ball. :wink:
PostPosted: Sat Aug 28, 2004 3:09 pm
thanks Doc youre a champ
