It is currently Sat Jul 19, 2025 8:27 pm
 Post subject: Reversing light switch
PostPosted: Mon Sep 27, 2004 3:48 pm
I've been looking for a reversing light switch for my remote change gearbox and today I found a mini at the wreakers with one on it.
I eventually managed to get it off and now I have a switch and a spring but did I miss something as I don't see how these two parts by themselves will work.
PostPosted: Mon Sep 27, 2004 4:00 pm
Simple- when you select reverse, the lockout plunger comes up, and closes the switch.. :wink:
The spring is just the lockout for reverse. I put a nice `red die spring' in there instead, so it's harder to get the reverse gate by mistake- when you really wanted 3rd gear.. 8) ..
PostPosted: Mon Sep 27, 2004 6:24 pm
Thanks for that.I didn't want to have to go back as with the front end the way it was it wasn't easy to get to.
I put the switch on and it didn't work.I've ended up having to add a small length of 5mm steel rod into the spring and now it works perfectly.
