It is currently Sat Jul 19, 2025 9:32 pm
 Post subject: 998 OVER bore
PostPosted: Sat Oct 02, 2004 7:39 pm
ok guys i have 'aquired ' a set of 73mm pistons , can a 998 block be bored to 73mm ? also does anyone have a set of 998 rods to suit pressfit gudeons? need a set I/F the block can be bored to 73mm. please god (kev) let this be possible
lookin for another clubby
PostPosted: Sun Oct 03, 2004 10:05 am
NO way you can bore a 998 or 1098 to 73.0mm. 68.0 will stop it, even to get that you need to offset bore. <edit> 68.0mm Imp pistons cost a fortune now, they gotta come from NZ or UK. :cry:
73.0mm in a 1275 will give you 1360cc, or 1405 if you stroke the crank. Go find a 1275 block... :lol:
Last edited by drmini in aust on Mon Oct 04, 2004 7:46 pm, edited 1 time in total.
PostPosted: Sun Oct 03, 2004 11:59 am
hey Doc
(someone obviously rather unreliable)
said A-series blocks were ALL the SAME
what made a 850 different to a 1275 was
different bore
different stroke
different accessories
Inconspicuously Conspicuous
PostPosted: Sun Oct 03, 2004 12:05 pm
998 and 1098 blocks are the same, different crank. the bores on a 1275 are physically in different places i believe (ie offset differently). I think an 850 block is the same as a 998 and 1098 but not sure..
'68 Morris Mini Matic (GF's)- complete!
'68 Morris Mini Deluxe - deciding on specs..
'63 Morris 850 - On the Shelf
Other various mini parts cars :)
PostPosted: Sun Oct 03, 2004 3:39 pm
Duc,
There are 2 basic block families-
850-997-998-1098 (small bore)
970-1071-1275 (big bore)
850 has only 1 cam bearing (front) and main bearings are wider than the others.
997 (rare now), -998-1098 are pretty much the same block.
They can all be offset bored to 68.0mm (1220cc with 1100 crank) if you are lucky.
850 blocks & bearing caps need machining to fit a 998 or 1098 crank in. I used to do it, years ago. Not worth it these days.
1275 block is taller than the 970 and 1071, which are both rare now.
1275 S block has side covers, the other 1275s (1100S, 1275LS, 1275A+) have a solid wall block. They can all be offset bored to 1380 (73.5mm) but the S block is a bit thinner in the walls. My spies tell me an A+ block is less reliably overbored than the earlier ones- more crap in the casting.
Any 1380 motor is supposedly a bit thin in the walls if you are going to turbo or supercharge the motor. Better to keep it to 1310 bore, stroke it if you want more cubes.
Bore centres for these 2 groups are totally different. The small bores have 1-2 and 3-4 siamesed, with a water passage between 2 & 3.
The big bores have them more or less equal spaced, a little thinner between 2-3. On all these there is no water passage between any of the cylinders. :wink:
Last edited by drmini in aust on Sun Oct 03, 2004 10:15 pm, edited 2 times in total.
PostPosted: Sun Oct 03, 2004 4:43 pm
answered all my questions with alittle bit left over too :wink:
PostPosted: Mon Oct 04, 2004 11:27 am
spewing
go find a 1275 block... :lol:
easier said than done m8 :(
PostPosted: Mon Oct 04, 2004 2:32 pm
Alright Ben, go find a 1275 AUTO block then. :lol:
Gotta be heaps lying around, nobody wants them. I'll convert it to manual for you if you like. :wink:
Or, ping `boostedmini', he has a couple of 1275 blocks for sale at the moment- one auto, one manual.
