It is currently Sat Jul 19, 2025 9:31 pm
 Post subject: Master Brake Cylinder
PostPosted: Mon Oct 04, 2004 8:21 pm
teh admin God
teh admin God
I was playing around with the mini, and unscrewed the master brake lid thing, and the seal or thing is completely submerged in the liquid. Apparently my master is losing pressure from somewhere, and i was going to get it reconditioned, but i didn't. So just wondering how needed this seal is to help the whole system, or is it just my lack of knowledge, as to what effects things!
And if i do get it reconditioned how much should it help the brakes,
and obviously they are drums
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Mon Oct 04, 2004 8:26 pm
the seal is to keep a nice 'seal' on the fluid, giving it a second skin.
when you run low on fluid, it pops down so that air doesnt get sucked into the pipes
it also stops dust n particles getting sucked in too
if the seal gets sucked down, it means you are using up brake fluid
mine kinda does it, comes out of my front brakes
1. gets soaked by dirt and more dirt when i drive, and i cant see the damage
2. if too much, it goes onto the floor, then i can see a problem
Inconspicuously Conspicuous
i just got my brake master cylinder rebuilt if it needs to be sleeved and all buy a new one its cheaper
PostPosted: Mon Oct 04, 2004 8:28 pm
if the seal keeps getting popped down, then youre losing fluid
and the fluid must be going somewhere
maybe its coming out from the bottom of your master
or one of the slaves
or your nipples are not stagged- i mean... tightened
PostPosted: Mon Oct 04, 2004 8:32 pm
check your bleed nipples also could be losing there
