Takes two reasonable size people to lift the body off the subframe. One really huge bastard could do it by yourself. You say you are are uni, well surely your mates will help. 3 mates + 1 slab = moke off subframe + 6 beers each.
is the "squelching" happening when you hit a bump? my left side upper suspension arm nylon cup had worn right through, and the knuckle was grinding away at the upper arm. made a horrible sound not unlike you describe. But it would happen more when the left side was loaded up i.e. turning right. Maybe the dodgy repair of the cone did not involve replacing the nylon cup?
There is a guy up in QLD who will sell you a late model UK twin circuit cylinder, and he also sells the repair kis so you won't be left in the same position in 5 years time...."Terry & Cindy @ ESP <
[email protected]> wrote:
We have a tandem cyl in stock that will suit. Brand new $260. This
is an English market cyl for non boosted disc brakes. We carry kits
for these as well.
Regards,
Cindy
ESP"
Might be worth a try - i never bought one because i did not really need it
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
